Keine Verbindung zur IP-Adresse, keine Fehler im Log
I am not sure how much information to include in this topic, so let me know if information should be added. Here is a summary:
  1. I am installing Discourse on a Digital Ocean droplet, using my own ssl keys.
  2. The initial install resulted in the IP resolving, but not the domain.
  3. When I added the ssl keys and then performed rebuild, neither domain nor IP resolved.
  4. The log file had several errors, and I resolved them one by one by looking up the causes in the Discourse forums. There are a couple remaining errors, but the forums said to disregard.
Below is the log file output:
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/enable-brotli
Started runsvdir, PID is 41
ok: run: redis: (pid 51) 0s
ok: run: postgres: (pid 55) 0s
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
2019-01-14T01:05:43.285264+00:00 Discourse-sfo2-01-app rsyslogd: [origin software="rsyslogd" swVersion="8.16.0" x-pid="59" x-info=] start
2019-01-14T01:05:43.280184+00:00 Discourse-sfo2-01-app rsyslogd-2307: warning: ~ action is deprecated, consider using the 'stop' statement instead  ]
supervisor pid: 52 unicorn pid: 80
This is the port info:
root@Discourse-sfo2-01:~# sudo netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1440/sshd
tcp6       0      0 :::22                   :::*                    LISTEN      1440/sshd
The domain is keepinglookout.com, and the ip is 178.128.2.158.
I look forward to any advice anyone has.
It looks like your ports 80 and 443 aren’t forwarding to your docker container.
Can you show us:
  • the errors you needed to resolve and the changes you made
  • output of docker ps on the server?
DNS “resolution” is the process of turning a name (keepinglookout.com) into an IP address (178.128.2.158). That’s the part that’s working:
○ → host keepinglookout.com
keepinglookout.com has address 178.128.2.158
I think what you mean is that you can’t connect to the name or IP?
Thank you for the quick reply! I believe nearly all the changes that I remember making that had appeared in the log were regarding “rsyslog”. For example, I changed “xconsole” to “console”, and commented out parts of the yml. I can provide you with the yml, but honestly I cannot remember the exact changes. I should have kept a record of that. Another change I made was in regards to the ssl files. The log said I had placed them in the wrong folder, and I believe the change in location fixed that problem.
You are correct that i intended to say that I just cannot connect to the name or IP.
Below is the docker ps:
CONTAINER ID        IMAGE                 COMMAND             CREATED             STATUS              PORTS               NAMES
8c697843abcf        local_discourse/app   "/sbin/boot"        3 hours ago         Up 3 hours                              app
Thanks again for the quick reply.
Also, regarding the following instructions found on this page ( Allow SSL / HTTPS for your Discourse Docker setup ):
Configure NGINX
Add a reference to the nginx ssl template from your app.yml configuration file:
templates:
  - "templates/sshd.template.yml"
  - "templates/web.ssl.template.yml"
Configure your Docker Container
Tell your container to listen on SSL
expose:
  - "80:80"
  - "2222:22"
  - "443:443"
Would I implement the above recommendations in the app.yml (as I understand them to read), or in some other place, such as the “docker container” or nginx ssl template?
Did you have a reason not to use Let’s encrypt as suggested in that topic?
Do you not have ports 443 and 80 in the expose section?
You’ve removed the part that tells docker to forward 80 (HTTP) and 443 (HTTPS) to Discourse. You need those in place.
You should follow this guide: Set up HTTPS support with Let's Encrypt
Yes, that expose command goes into your app.yml
I initially tried to use Let’s Encrypt, but after many, many attempts was unsuccessful (many dozen, I am sure). I then decided to attempt adding my own SSL. After dozens of attempts there, I decided to post my forum question. I nearly decided to pay someone to configure for me since I lost so much time in failed attempts. I cannot say it was a total loss, though, because I learned a lot about the process along the way and became VERY familiar with the instructions.
Ultimately, today, I decided to attempt Let’s Encrypt again. I noticed a sentence in the instructions I had never noticed before,
Note: ./discourse-setup will enable Let’s Encrypt. And as of March 2017, you can run it again, and press return a few times and enter your email address ; the script will include the required templates and insert your email address as required. If you installed Discourse a long time ago , you might still have to edit app.yml by hand.
This was what I was missing. I was apparently over-configuring by editing the yml. Today I was successful, though. Hooray!
I’m not sure if the process is too simple or if the “how-to” instruction is not clear enough, but I have spent an embarrassing amount of time troubleshooting this problem.
I really like this forum, though. Everyone is very helpful and the responses from people are fast! I look forward to learning more from you all and playing with the product.
Thank you for the response. I un-commented the corresponding portion of that yml countless times. I even learned yml validation in the process. Oddly, in my case, I was able to resolve my problem without editing the yml today. Like I said in my other comment moments ago, the key sentence in the installation how-to has been staring at me for a week while I made a thousand different errors that brought me back to square one and forced me to re-read the how-to more carefully:
