Recently I installed the experimental form templates
feature as reported, but after creating a form for the category, the “create topic” button did not work.
Do I need to install anything else to enable this feature?
No as long as you enable the feature in settings, create a template and assign it to a category it’ll work.
Are there any errors in logs and does it occur in safe mode?
Thank you, after trying to turn off the plugins one by one, the form template feature is working, they are affected by the “Perspective Api” plugin, this is an offical plugin, I hope the discourse team can check and correct it.
