App kann nicht neu aufgebaut werden
Hier protokollieren:
[2025-03-31T05:52:21.927771 #1]  INFO -- : > cd /var/www/discourse & if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "Diese Version von Discourse verwendet yarn, aber pnpm node_modules sind bereits vorhanden. Bereinige..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile & yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile & pnpm prune'
fi
bash: line 1:   302 Killed                  CI=1 pnpm install --frozen-lockfile
I, [2025-03-31T05:52:29.299652 #1]  INFO -- : Scope: all 17 workspace projects
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +455 -114
Progress: resolved 455, reused 170, downloaded 50, added 119
Progress: resolved 455, reused 170, downloaded 187, added 257
Progress: resolved 455, reused 170, downloaded 281, added 349
Progress: resolved 455, reused 170, downloaded 285, added 357, done
.../core-js@3.33.0/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../node_modules/@swc/core postinstall$ node postinstall.js
.../esbuild@0.24.2/node_modules/esbuild postinstall$ node install.js
.../core-js@3.33.0/node_modules/core-js postinstall: Done
.../node_modules/@swc/core postinstall: Failed
FAILED
Pups::ExecError: cd /var/www/discourse & if [ -f yarn.lock ]; then
  fi
else
fi failed with return #<Process::Status: pid 299 exit 137>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ -f yarn.lock ]; then\n  if [ -d node_modules/.pnpm ]; then\n    echo \"This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up...\"\n    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +\n  fi\n  su discourse -c 'yarn install --frozen-lockfile & yarn cache clean'\nelse\n  su discourse -c 'CI=1 pnpm install --frozen-lockfile & pnpm prune'\nfi"]}
bootstrap failed with exit code 137
Wenn ich mich recht erinnere, bedeutet Exit 137, dass der Speicher voll ist.
Fügen Sie mehr RAM und/oder erhöhen Sie den Swap-Speicher. Sie benötigen wahrscheinlich mindestens 5 GB Swap+RAM.
               total        used        free      shared  buff/cache   available
Mem:            31Gi       4.1Gi        17Gi       3.5Mi       9.9Gi        27Gi
Swap:          8.0Gi          0B       8.0Gi
aber mein Server hat genug Arbeitsspeicher.. @pfaffman
Das ist sehr seltsam. 137 bedeutet, dass der Job ein SIGKILL erhalten hat, was normalerweise auf Speicherüberlauf hinweist.
Es macht jedoch keinen Sinn bei so viel Speicher.
Das ist seltsam.
Überprüfen Sie vielleicht die Ausgabe von
sysctl vm.overcommit_memory
Und auch:
cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.2 LTS"
$ uptime
 02:12:36 up 21 days,  5:25,  2 users,  load average: 0.02, 0.18, 0.26
$ df -h /
Filesystem                             Size  Used Avail Use% Mounted on
/dev/mapper/vg0--root-root--partition  492G   29G  463G   6% /
$ free
Mem:        32819356     4093776    19016296        3576    10185012    28725580
Swap:        8388604           0     8388604
$ swapon
NAME      TYPE SIZE USED PRIO
/swap.img file   8G   0B   -2
$ vmstat 5 5
procs -----------memory---------- ---swap-- -----io---- -system-- -------cpu------
 r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
 2  0      0 18944824   3620 10211784    0    0     2    81 1057    1  1  0 99  0  0
 0  0      0 18965764   3620 10195160    0    0     0   123 8661 10955  3  6 91  0  0
 2  0      0 18953904   3620 10203228    0    0     0     9 3388 3559  1  1 98  0  0
 1  0      0 18864336   3620 10292272    0    0     3  3408 8327 10272  6  4 90  0  0
 9  3      0 17795380   3620 10561284    0    0  1666 33519 29310 41403 27 27 44  1  0
dmesg|egrep -i "memory|oom|kill"
none
$ ps auxrc
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
td20      347732  200  0.0  21408  5588 pts/1    R+   02:16   0:00 ps
$ sysctl vm.overcommit_memory
vm.overcommit_memory = 0
@Ed_S
Mir ist aufgefallen, dass der Prozess schnell beendet wird, wenn die Speicherauslastung 1 GB überschreitet.
Danke… Es ist mir immer noch ein Rätsel. Aber ich würde dringend empfehlen, mit Overcommit zu arbeiten. Sie können es jetzt einstellen mit
sudo sysctl vm.overcommit_memory=1
aber es dauerte etwas mehr Mühe, es auch beim Neustart einzustellen. Es könnte alles zum Laufen bringen, in diesem Fall ist es richtig, es persistent zu machen. Es sieht so aus, als ob ich es getan habe, indem ich eine einzeilige Datei erstellt habe:
# cat /etc/sysctl.d/90-vm_overcommit_memory.conf
Wenn das nicht hilft, fühlt es sich an, als ob ein Watchdog oder eine Quote nach Ressourcenüberlastung sucht und Prozesse beendet. Möglicherweise hilft ein genauer Blick auf die vollständige dmesg-Ausgabe - wenn Sie kürzlich den Ausfall hatten, könnten die letzten 100 Zeilen vielleicht einen Hinweis geben.
