I get the following error when trying to rebuild. Saw similar thread in here and removed some plugins but that didnt resolve the issue
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile:build' failed with return #<Process::Status: pid 666 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"build", "hook"=>"assets_precompile_build", "cmd"=>["su discourse -c 'bundle exec rake assets:precompile:build'"]}
4490985a65ce2bcadfb9a4dbf82c674b9fd999dc32d42cc9e7c3c265f73c9c6c
I’ve encountered this problem, sometimes it’s not the problem that the RAM memory is too small, it should be caused by it not manually allocating RAM for docker, before restoring your website backup, you must first execute the ./discourse-setup command, and then he will automatically allocate memory for Docker, and then you can ctrl + C to terminate the command, upload the backup app.yml proceed ./launcher rebuild app
