js.composer.error.post_length 텍스트를 업데이트하려고 합니다. 프로덕션, 스테이징 및 로컬 환경에서 2.9 및 3.1.0.beta2 버전을 사용 중이며 이 문제를 겪고 있습니다.
값이 설정되어 있음에도 불구하고 FE(프론트엔드)에는 [missing {{min}} value]라고 표시됩니다.
오류 로그에는 다음과 같이 표시됩니다:
NoMethodError (undefined method `scan' for {:one=>"Post must be at least %{count} character", :other=>"Post must be at least %{count} characters"}:Hash keys = text.scan(pattern) ^^
Message
lib/i18n/i18n_interpolation_keys_finder.rb:6:in `find'
app/models/translation_override.rb:123:in `check_interpolation_keys'
app/models/translation_override.rb:64:in `upsert!'
app/controllers/admin/site_texts_controller.rb:88:in `update'
app/controllers/application_controller.rb:414:in `block in with_resolved_locale'
app/controllers/application_controller.rb:414:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/missing_avatars.rb:22:in `call'
lib/middleware/turbo_dev.rb:31:in `call'
Backtrace
activesupport (7.0.4) lib/active_support/callbacks.rb:400:in `block in make_lambda'
activesupport (7.0.4) lib/active_support/callbacks.rb:199:in `block (2 levels) in halting'
activesupport (7.0.4) lib/active_support/callbacks.rb:687:in `block (2 levels) in default_terminator'
activesupport (7.0.4) lib/active_support/callbacks.rb:686:in `catch'
activesupport (7.0.4) lib/active_support/callbacks.rb:686:in `block in default_terminator'
activesupport (7.0.4) lib/active_support/callbacks.rb:200:in `block in halting'
activesupport (7.0.4) lib/active_support/callbacks.rb:595:in `block in invoke_before'
activesupport (7.0.4) lib/active_support/callbacks.rb:595:in `each'
Env
HTTP HOSTS: 127.0.0.1:3000
