לא ניתן להעלות אווטארים עם S3 Storage מופעל (הקובץ קיים, עדיין נכשל)
Hi all,
I’m facing a strange issue with Discourse + S3 storage.
When uploading avatars, I get an error like the one below — even though the file does exist on the S3 bucket and is accessible via a valid s3_cdn_url.
Uploads for posts and attachments work perfectly. The only thing that fails is user avatar uploads.
:fire: Error message from gig.ovh/logs
Message (2 copies reported)
Could not find file in the store located at url: //gig.s3.ru-1.storage.selcloud.ru/original/1X/fd42dfa3362b66090450f2ae40f0917193fcd355.jpeg
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active\_support/broadcast\_logger.rb:134\:in `block in error'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active\_support/broadcast\_logger.rb:231\:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/broadcast_logger.rb:231:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active\_support/broadcast\_logger.rb:134\:in `error'
/var/www/discourse/app/models/optimized_image.rb:91:in `block in create\_for'
/var/www/discourse/app/models/optimized\_image.rb:19\:in `block (2 levels) in lock'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed\_mutex.rb:49\:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed\_mutex.rb:34\:in `synchronize'
/var/www/discourse/app/models/optimized_image.rb:19:in `block in lock'
/var/www/discourse/lib/distributed\_mutex.rb:53\:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/app/models/optimized\_image.rb:18\:in `lock'
/var/www/discourse/app/models/optimized_image.rb:83:in `create\_for'
/var/www/discourse/app/models/upload.rb:151\:in `get_optimized_image'
/var/www/discourse/app/controllers/user_avatars_controller.rb:219:in `get\_optimized\_image'
/var/www/discourse/app/controllers/user\_avatars\_controller.rb:137\:in `show_in_site'
/var/www/discourse/app/controllers/user_avatars_controller.rb:90:in `block (2 levels) in show'
/var/www/discourse/lib/hijack.rb:68\:in `instance_eval'
/var/www/discourse/lib/hijack.rb:68:in `block (2 levels) in hijack'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/i18n-1.14.7/lib/i18n.rb:353\:in `with_locale'
/var/www/discourse/lib/hijack.rb:68:in `block in hijack'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/concurrent-ruby-1.3.5/lib/concurrent-ruby/concurrent/promises.rb:911\:in `callback_on_resolution'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/concurrent-ruby-1.3.5/lib/concurrent-ruby/concurrent/promises.rb:797:in `call\_callback'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/concurrent-ruby-1.3.5/lib/concurrent-ruby/concurrent/promises.rb:803\:in `call_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/concurrent-ruby-1.3.5/lib/concurrent-ruby/concurrent/promises.rb:692:in `resolve\_with'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/concurrent-ruby-1.3.5/lib/concurrent-ruby/concurrent/promises.rb:1325\:in `resolve'
/var/www/discourse/lib/scheduler/defer.rb:125:in `block in do\_work'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails\_multisite-6.1.0/lib/rails\_multisite/connection\_management/null\_instance.rb:49\:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with\_connection'
/var/www/discourse/lib/scheduler/defer.rb:119\:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:105:in `block (2 levels) in start\_thread'
That is an S3 URL for the container
The image is available at URL:
https://s3.gig.ovh/original/1X/fd42dfa3362b66090450f2ae40f0917193fcd355.jpeg
:white_check_mark: Additional Info
  • Discourse version: (latest stable)
  • External S3-compatible storage used (enable_s3_uploads = true)
  • s3_cdn_url is correctly configured and used
  • CDN URL successfully returns the file
  • File is confirmed present at the expected S3 location
  • Other uploads (images, attachments, etc.) work fine
  • The error only occurs with user avatars
:red_question_mark:Question
What could cause Discourse to fail to retrieve the file for avatar processing while the exact file exists and is reachable via the correct CDN URL?
Is there something specific to avatar processing (like get_optimized_image) that could be misconfigured or cached incorrectly?
Any suggestions or insight would be appreciated!
Thanks :folded_hands:
Hi there — did you ever resolve this?
I’m hitting the exact same symptom on Discourse + S3 (avatars only):
Could not find file in the store located at url: //<bucket>.s3.dualstack.<region>.amazonaws.com/original/1X/<hash>.jpeg
A few details on my setup, in case it matches yours:
  • enable_s3_uploads = true, objects live at original/* and optimized/* (no uploads/default prefix)
  • Access via CloudFront (OAC), bucket itself is private
  • The object does exist at that key; CDN URL works
  • Error occurs only for avatar processing
  • (Possible wrinkle) uploads are encrypted with SSE-KMS
If you found the root cause or a fix (policy change, KMS permissions, bucket path alignment, etc.), could you share what worked? Thanks!
