Cannot yarn or run ember-cli on MacOS Sonoma 14.5
A user, merefield, encountered an issue on MacOS Sonoma 14.5 where they were unable to run yarn or ember-cli due to an error. The error indicated that it couldn’t find a match for a specific Git commit hash. However, merefield was able to resolve the issue by running yarn cache clean.
Cannot yarn or run ember-cli on Sonoma 14.5 for main
Getting an error/stuck here:
⠁ squoosh@discourse/squoosh#dc9649d
which eventually leads to
error Couldn't find match for "dc9649d" in "refs/heads/abortable-task,refs/heads/abstracting-util,refs/heads/analytics,refs/heads/android-tablet-bugs,refs/heads/api,refs/heads/asdf,refs/heads/assemblyscript-experiment,refs/heads/avif-header-patch,refs/heads/basis,refs/heads/chroma-subsample,refs/heads/cli-invoc,refs/heads/cli-invoc-2,refs/heads/console-feed,refs/heads/copy-to-side-ui,refs/heads/critters-async-await,refs/heads/css-inlining,refs/heads/dependabot/cargo/codecs/hqx/bumpalo-3.12.0,refs/heads/dependabot/cargo/codecs/oxipng/bumpalo-3.12.0,refs/heads/dependabot/cargo/codecs/png/bumpalo-3.12.0,refs/heads/dependabot/cargo/codecs/resize/bumpalo-3.12.0,refs/heads/dependabot/npm_and_yarn/postcss-8.4.31,refs/heads/detect-images-on-main,refs/heads/dev,refs/heads/disable-terminate-on-dev,refs/heads/discourse,refs/heads/enter-fix,refs/heads/extract-pinch-zoom,refs/heads/filedrop-wc,refs/heads/hotfix-avif-threads,refs/heads/hqx-fix,refs/heads/jpeg-simd,refs/heads/jxl-noise-effort,refs/heads/jxl-rebuild,refs/heads/jxl-xyb,refs/heads/karmatic,refs/heads/kosamari-patch-1,refs/heads/kosamari-patch-2,refs/heads/latest-wasm-opt-in-rust,refs/heads/lighthouse-ci,refs/heads/live,refs/heads/main-ui,refs/heads/mobile-chrome-glitch-fix,refs/heads/mobile-ui,refs/heads/mozjpeg-wasi,refs/heads/normalize-src,refs/heads/one-pass-progressive,refs/heads/options-ui,refs/heads/oxipng-old,refs/heads/parallel-oxipng,refs/heads/parcel2,refs/heads/pk-spelling,refs/heads/plan-b,refs/heads/pointer-tracker-import,refs/heads/precise-unit-labels,refs/heads/preprocessor-transformations,refs/heads/preprocessor-transformations-rebased,refs/heads/prerendering,refs/heads/readme-typos,refs/heads/renovate/assets-webpack-plugin-3.x,refs/heads/renovate/chokidar-3.x,refs/heads/renovate/clean-webpack-plugin-3.x,refs/heads/renovate/comlink-4.x,refs/heads/renovate/copy-webpack-plugin-5.x,refs/heads/renovate/css-loader-3.x,refs/heads/renovate/ejs-2.x,refs/heads/renovate/husky-3.x,refs/heads/renovate/node-10.x,refs/heads/renovate/optimize-css-assets-webpack-plugin-5.x,refs/heads/renovate/preact-8.x,refs/heads/renovate/sass-loader-8.x,refs/heads/renovate/ts-loader-6.x,refs/heads/renovate/typed-css-modules-0.x,refs/heads/renovate/typescript-3.x,refs/heads/renovate/webcomponents-custom-elements-1.x,refs/heads/renovate/webpack-4.x,refs/heads/renovate/webpack-cli-3.x,refs/heads/renovate/webpack-cli-serve-0.x,refs/heads/renovate/worker-plugin-3.x,refs/heads/rollup-build,refs/heads/rotation-optimise,refs/heads/sentry,refs/heads/snackbar-timeout-undo,refs/heads/surma-patch-1,refs/heads/testing,refs/heads/threads,refs/heads/tiling-rust,refs/heads/update-resize-2,refs/heads/urls-bug,refs/heads/v2-codecs,refs/heads/visdif-error,refs/heads/warn-on-unavailable-worker,refs/heads/web-codecs,refs/heads/webp-lossless-fix,refs/heads/webpack-dev,refs/heads/webpack-wasm,refs/heads/windows-build-fix,refs/heads/wp2-options,refs/pull/1/head,refs/pull/10/head,refs/pull/11/head,refs/pull/12/head,refs/pull/13/head,refs/pull/14/head,refs/pull/15/head,refs/pull/16/head,refs/pull/17/head,refs/pull/18/head,refs/pull/19/head,refs/pull/2/head,refs/pull/20/head,refs/pull/21/head,refs/pull/22/head,refs/pull/23/head,refs/pull/24/head,refs/pull/25/head,refs/pull/26/head,refs/pull/27/head,refs/pull/28/head,refs/pull/29/head,refs/pull/3/head,refs/pull/30/head,refs/pull/30/merge,refs/pull/31/head,refs/pull/31/merge,refs/pull/32/head,refs/pull/32/merge,refs/pull/33/head,refs/pull/33/merge,refs/pull/34/head,refs/pull/34/merge,refs/pull/35/head,refs/pull/36/head,refs/pull/37/head,refs/pull/4/head,refs/pull/5/head,refs/pull/6/head,refs/pull/7/head,refs/pull/8/head,refs/pull/9/head,refs/tags/v1.10.0,refs/tags/v1.10.1,refs/tags/v1.10.2,refs/tags/v1.10.3,refs/tags/v1.10.4,refs/tags/v1.11.1,refs/tags/v1.11.2,refs/tags/v1.11.3,refs/tags/v1.12.0,refs/tags/v1.2.0,refs/tags/v1.2.1,refs/tags/v1.2.2,refs/tags/v1.2.3,refs/tags/v1.3.0,refs/tags/v1.3.1,refs/tags/v1.3.2,refs/tags/v1.3.3,refs/tags/v1.3.4,refs/tags/v1.4.0,refs/tags/v1.5.0,refs/tags/v1.6.0,refs/tags/v1.7.0,refs/tags/v1.8.0,refs/tags/v1.8.1,refs/tags/v1.9.0,refs/tags/v1.9.1,refs/tags/v1.9.2" for "https://github.com/discourse/squoosh.git".
Unstuck with a:
yarn cache clean
