לא ניתן ליצור קבוצת חדשה דרך ה-API (/admin/groups.json - שיטת פוסט)
Can’t create new group via api (https://mywebsite/admin/groups.json - post method)
When I send via get method (https://mywebsite/groups.json) I successfully get all groups list.
Response message is “The requested URL or resource was not found”
Hi,
Can you share details on how you create a group?
Did you provide valid Api-Key and Api-Username headers?
curl “https://community.orleu-edu.kz/admin/group.json
-X POST
-d “{\r\n "group": {\r\n "name": "dfgdfg"\r\n }\r\n}”
-H “Content-Type: multipart/form-data”
-H “authorization: Bearer my token”
-X POST
-d “{\r\n "group": {\r\n "name": ""\r\n }\r\n}”
-H “Api-Key: key”
-H “Api-Username: nakimbekov”
This requests return same error
Not found suggests that your key isn’t working. You can look at the logs and maybe get more info.
You can try a known bad key and see that you get the same error.
I would generate a new global key and try it.
