Can't delete invitations sent or abandon post draft
Can’t delete invitations sent or abandon post draft
User Andrea_Giovacchini is experiencing issues on their Discourse site (http://discourse.apicolturaitalianafb.it), including being unable to delete sent invitations or abandon post drafts. They’ve encountered a “Request Timeout” error and have provided browser console logs.
Dani suspects a configuration issue and suggests checking the cloud installation guide. Andrea_Giovacchini responds that they followed the guide and have provided their app.yml file, which includes HAPROXY routing requests to Apache for other sites and the Discourse app.
Andrea_Giovacchini mentions that they also have an issue with connecting to Redis, which they’ve posted about separately: Error connecting to Redis on localhost:6379 (errno=EADDRNOTAVAIL).
I’m running 2.7.0.beta5 and I get this error registered in log while trying:
Uncaught Error: Request Timeout Url: http://discourse.apicolturaitalianafb.it/assets/ember_jquery-36a23101c869ab0dc53fc908de69adb785731593573d32bdeef416acc1076ef4.js Line: 1 Column: 266799 Window Loca
And this in the browser console:
Same with stable 2.6.3
You can try at http://discourse.apicolturaitalianafb.it
Hello Andrea,
The issues you showed up in the console (408 - timed out) and the fact that you have the same problem with stable makes me think that something may be wrong with your configuration. I tried accessing your site, but that has not been available for the past few hours (503 - Service unavailable).
Did you follow our cloud installation guide? Can you provide any additional information about server’s specifications?
Hi @dan , the site was down because I was trying to understand the problem so I’ve reinstalled many times. I also tryed moving from a subdomain to a “normal” domain, to see if that can be related , now discourse is on http://apicolturaitalianawebinar.it/
Yes I followed the guide.
This is my app.yml, and I have HAPROXY routing requests to Apache for other sites and discourse app for this.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "8888:80"   # http
  - "8443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  version: stable
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  UNICORN_WORKERS: 4
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'discourse.apicolturaitalianafb.it'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'xxx@gmail.com,yyy@libero.it'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: xxx
  DISCOURSE_SMTP_PORT: xxx
  DISCOURSE_SMTP_USER_NAME: xxx@apicolturaitalianafb.it
  DISCOURSE_SMTP_PASSWORD: xxx
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  DISCOURSE_SMTP_DOMAIN: xxxx    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: xxxx    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
@dan I answered you but I have a notification that Askimet has hidden my comment :frowning:
I have also this error for which I made another post: Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL)
