Can't import view
Something weird happening with importing modules. Here’s a snippet from my plugin
import PostModel from 'discourse/models/post';
import { withPluginApi } from 'discourse/lib/plugin-api';
import { slot, loadGoogle } from '../lib/gpt';
import TopicView from 'discourse/views/topic';
The first three imports work well, but the last one doesn’t work and i don’t know how to figure out why.
The error: Uncaught ReferenceError: TopicView is not defined
Do you have any idea why importing TopicView doesn’t work?
class TopicView is in ./lib/topic_view.rb , so
maybe try:
import TopicView from 'discourse/lib/topic_view';
No, it’s a javascript part of Discourse, no ruby at all. In repo it has full path:
app/assets/javascripts/discourse/views/topic.js.es6
Shows what I know. :slight_smile:
I admit I’m no expert here.
But it seems odd to me that
/models/post.js.es6 has export default Post;
while
/views/topic.js.es6 has export default TopicView;
My guess is that the line should be
import Topic from 'discourse/views/topic';
in the assumption that topic is exporting TopicView as Topic
No difference.
I found another weirdo, here’s bigger snippet:
// here TopicView is defined
export default {
  initialize(container) {
    PostModel.reopen({
    // but here TopicView is not defined
TopicView is accessible out of anonymous object, but not inside it. But i don’t understand why there’s no problem with PostModel?
The directory views doesn’t exist in discourse 1.8 so i don’t find the class TopicView…
Does the TopicView class still exist in js ?
