Error in loading topics
I was trying to upload a topic on discourse which had 5 megs of images. For some weird reasons it kept on uploading until I closed the browser. Since then none of the topics load for me. I can login. See all the topics but when I click on any topic it keeps loading and nothing happens. Here is the error logs which I see.
Error: Could not find module `discourse/mixins/string-buffer` imported from `discourse/plugins/discourse-links-category/discourse/components/featured-link`
    at o (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:16:18039)
    at i (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:16:17964)
    at r.state (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:16:19107)
    at e (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:16:17423)
    at requireModule (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:16:19092)
    at h.customResolve (http://forum.investmentswise.com/assets/application-3713325460077ca066eae4e359902a7791493745096cf95c131167168ce9c857.js:1:14174)
    at h.resolveComponent (http://forum.investmentswise.com/assets/application-3713325460077ca066eae4e359902a7791493745096cf95c131167168ce9c857.js:1:14762)
    at h.resolve (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:5:383)
    at i.t [as resolver] (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:4:25128)
    at o (http://forum.investmentswise.com/assets/ember_jquery-5bc98ec46a799a78ead48d23df534d67c737906cdc100d826b0a001a8a1c1b8b.js:4:5095)
Are you running the latest version of Discourse? Do you have any plugins installed?
yeah I have the latest version. Got some plugins like cakeday and solved
Scratch that. I didn’t read the backtrace properly :sunglasses:
Can you try disabling the discourse-links-category plugin?
The first line of the plugin say that the error is in discourse-links-category plugin.
It probably got hit by an update. Please disable it and try again.
okay. I am going to try it now
okay @Falco doing it now
thanks @Falco and @zogstrip . the issue is gone. Also does it mean that I cannot install the plugin? Is it incompatible now?
Yes. However, this plugin will soon be part of the core Discourse software, so just wait a bit I guess.
For anyone interested, here’s the announcement of that feature
