Can't login after removing all bot user agents from site setting
AI 生成的摘要
A new Discourse user, atb1248, accidentally broke admin login after removing all bot user agents from a site setting while trying to block crawlers. Despite setting allow index in robots txt to false, the issue stemmed from emptying the crawler user agent list — which inadvertently blocked login access, even in browsers. zogstrip suggested using /u/admin-login to bypass the issue, which worked for login, but admin pages remained inaccessible due to missing navigation menus as shown in screenshots. zogstrip then provided SSH instructions to restore the setting via Rails console: SiteSetting.crawler_user_agents = "*". atb1248 confirmed the fix worked after applying it the next day, thanking the community for the quick, precise help. Note: Since the site is invite-only, blocking crawlers was unnecessary — bots can’t access it anyway.
Disclaimer : I have 24 hours of experience with Discourse.
I just set up a new Discourse (amazing deployment experience by the way, https support was magic), in invite-only mode. I wanted to disallow crawlers and referencement and might have gone too far in this. I set allow index in robots txt to false but also removed all the bot user agents from the list in a setting that was just under. Sadly, I cannot remember the name of this setting or find it in the api. Since this, it’s impossible to access the admin panel and trying another browser doesn’t work since the login doesn’t work either (there’s no button).
the robots.txt looks fine:
User-agent: *
Disallow: /
I am not 100% confident that my emptying of that user-agent list is the root cause, so I’m open to other interpretations.
I do not have an API key yet, so I suppose I’ll have to fix this by SSH. Any idea on the steps involved to rebuild that list and fix this?
Have you tried logging in using https://your.discourse/u/admin-login?
This does indeed work for login.
It appears I do not have access to the admin and settings pages though, here’s a screenshot from the front page (no menu in headers).
And another from /admin.
Here’s how to fix your issue
# ssh into your server
cd /var/discourse
./launcher enter app
rails c
BTW, if your site is invite only, no bot will be able to crawl it :wink:
I’m unable to ssh into the machine until tomorrow, at which point I’ll let you know the result of those commands.
Thanks a lot for the quick responses.
This did it. Thanks a lot for the quick and concise help!
