Je viens de faire une mise à jour en utilisant ./launcher rebuild app et le site web est maintenant inaccessible. Il n’y a eu aucune erreur lors de la mise à niveau de Postgres ou de la reconstruction. Voici la sortie de discourse doctor.
DISCOURSE DOCTOR Tue Feb 4 10:56:05 PM UTC 2025
OS: Linux redacted 6.8.0-52-generic #53-Ubuntu SMP PREEMPT_DYNAMIC Sat Jan 11 00:06:25 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=redacted.tld
SMTP_ADDRESS=cp120.redacted.net
DEVELOPER_EMAILS=host@redacted.tld
SMTP_PASSWORD=redacted
SMTP_PORT=587
SMTP_USER_NAME=record@redacted.tld
LETSENCRYPT_ACCOUNT_EMAIL=host@redacted.tld
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 26.1.3, build 26.1.3-0ubuntu1~24.04.1
DOCKER PROCESSES (docker ps -a)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
26b5f30922a1 local_discourse/app \"/sbin/boot\" 14 minutes ago Up 12 minutes 0.0.0.0:80-\u003e80/tcp, :::80-\u003e80/tcp, 0.0.0.0:443-\u003e443/tcp, :::443-\u003e443/tcp app
Discourse container app is running
==================== PLUGINS ====================
- sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git
- sudo -E -u discourse git clone https://github.com/discourse/discourse-data-explorer.git
- sudo -E -u discourse git clone https://github.com/discourse/discourse-affiliate.git
## - sudo -E -u discourse git clone https://github.com/paviliondev/discourse-locations.git
## - sudo -E -u discourse git clone https://github.com/paviliondev/discourse-events.git
## - sudo -E -u discourse git clone https://github.com/paviliondev/discourse-custom-wizard.git
## - sudo -E -u discourse git clone https://github.com/gdpelican/mingle.git
## - sudo -E -u discourse git clone https://github.com/synweap15/discourse-voice-record.git
- sudo -E -u discourse git clone https://github.com/discourse/discourse-docs.git
- sudo -E -u discourse git clone https://github.com/discourse/discourse-calendar.git
- sudo -E -u discourse git clone https://github.com/discourse/discourse-adplugin.git
WARNING:
You have what appear to be non-official plugins.
If you are having trouble, you should disable them and try rebuilding again.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
Discourse version at redacted.tld: NOT FOUND
Discourse version at localhost: NOT FOUND
==================== MEMORY INFORMATION ====================
RAM (MB): 4005
total used free shared buff/cache available
Mem: 3820 1257 1137 52 1788 2562
Swap: 2047 75 1972
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
Filesystem Size Used Avail Use% Mounted on
/dev/sda1 38G 6.0G 30G 17% /
/dev/sdb 25G 11G 13G 46% /var/discourse
/dev/sdb 25G 11G 13G 46% /var/lib/docker
==================== DISK INFORMATION ====================
Disk /dev/sda: 38.15 GiB, 40961572864 bytes, 80003072 sectors
Disk model: QEMU HARDDISK
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 4F4C86C1-C38F-4B0C-BA8A-01C10D997AE4
Device Start End Sectors Size Type
/dev/sda1 528384 80003038 79474655 37.9G Linux filesystem
/dev/sda14 2048 4095 2048 1M BIOS boot
/dev/sda15 4096 528383 524288 256M EFI System
Partition table entries are not in disk order.
Disk /dev/sdb: 25 GiB, 26843545600 bytes, 52428800 sectors
Disk model: Volume
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Or just send a test message to yourself.
Email address for mail test? ('n' to skip) [host@redacted.tld]:
Sending mail to host@redacted.tld. . .
Testing sending to host@redacted.tld using cp120.redacted.net:587, username:record@redacted.tld with plain auth.
SMTP server connection successful.
Sending to host@redacted.tld. . .
Mail accepted by SMTP server.
Message-ID: a9640924-a68b-4e5e-a769-3110de133c08@redacted.tld
If you do not receive the message, check your SPAM folder
or test again using a service like http://www.mail-tester.com/.
If the message is not delivered it is not a problem with Discourse.
Check the SMTP server logs for the above Message ID to see why it
failed to deliver the message.
Replacing: SMTP_PASSWORD
Replacing: LETSENCRYPT_ACCOUNT_EMAIL
Replacing: DEVELOPER_EMAILS
Replacing: DISCOURSE_DB_PASSWORD
Replacing: Sending mail to
==================== DONE! ====================
Une idée de ce qui pourrait se passer ?
