Kan back-up van business 7 niet herstellen naar schone installatie vanwege versie-fout
pfaffman encountered an error restoring a backup from a Discourse Business 7 instance to a freshly rebuilt container, due to a version mismatch: the backup was from a newer schema version (20220112091339) than the target (20220107014925). Despite the target container appearing to be on a newer git commit (c758e2c), the restore failed because the version number embedded in the backup metadata was higher. Attempts to run migrations manually didn’t resolve it. gerhard suggested the issue might stem from a missing plugin migration and proposed renaming the backup file to bypass the version check. pfaffman confirmed this workaround worked and plans to rebuild the container with likely plugins to ensure compatibility when merging sites. The root cause appears to be a version metadata mismatch, not actual code versioning, and the fix was simple file renaming — though installing relevant plugins is still recommended for full functionality.
I have a freshly rebuilt container that is refusing to restore a backup taken hours ago from
Your branch is up to date with 'origin/tests-passed'.
nothing to commit, working tree clean
root@meshack-five:/var/www/discourse# git log
commit c758e2cdd17cc7f8cc44596e72d60e81b5bd8def (grafted, HEAD -> tests-passed, origin/tests-passed)
Author: Joffrey JAFFEUX <j.jaffeux@gmail.com>
Date:   Fri Jan 14 15:51:31 2022 +0100
But when I try to restore, I get …
Copying archive to tmp directory...
Unzipping archive, this may take a while...
Extracting dump file...
Validating metadata...
  Current version: 20220107014925
  Restored version: 20220112091339
EXCEPTION: You're trying to restore a more recent version of the schema. You should migrate first!
I tried doing a SKIP_POST_DEPLOYMENT_MIGRATIONS=false rake db:migrate to see if that would help, but no joy.
https://five.imports.literateforums.com/ shows
    <meta name="generator" content="Discourse 2.8.0.beta11 - https://github.com/discourse/discourse version c758e2cdd17cc7f8cc44596e72d60e81b5bd8def">
Source on the hosted site (on business7) shows:
   <meta name="generator" content="Discourse 2.8.0.beta11 - https://github.com/discourse/discourse version 6272edd1219652a8e1c9c33e16229b029cec603c">
I checked the commits at Commits · discourse/discourse · GitHub and it looks like my server is more up to date.
I feel like I must be doing something stupid, but I can’t see what it could be
Probably just a migration from a plugin that isn’t installed on your system. Replacing the version number in the filename should solve it.
Aha. I was wondering about plugins and whether I needed to install them all. And renaming the file is embarrassingly simple. :man_shrugging:
That worked, but I’ll rebuild with the plugins likely to be at play in case something needs to be there when I merge these two sites.
Thanks very much.
