No puedo entender cómo reemplazar Palabras Vistas
Previously we were using the Auto-Linkify theme component, but now unable to do that as we discontinue use of it.
So now we’re trying to work with the built-in Watched Words feature, and doing a Replace with RegEx.
We’re using Height for our tickets, which are all numbered like T-123 and then the URL just uses that T-123 behind a / to create the link.
The expression (T\-\d*) can successful capture the T-123 example, but I can’t get the $1 to be replaced by it. Ideally it would produce a link that’s like [T-123](https://xmtp.height.app/T-123). How do I go about this?
This is what I had entered into Watched Words, though I recognize that it wouldn’t actually do the same as before (auto linkify).
CleanShot 2021-10-14 at 16.25.47@2x
2 Me gusta
No sé que la captura y el reemplazo de expresiones regulares sean compatibles con Palabras vigiladas, solo la coincidencia, no la captura y el reemplazo.
2 Me gusta
Entendido. Y sí, es una lástima. Esperaba poder obtener la misma funcionalidad que tenía en Auto-linkify con las funciones integradas, ya que eso era todo lo que estaba disponible en Discourse for Teams.
¡Aún así, me gustaría ver esta funcionalidad algún día!
3 Me gusta
