Cant set up passkey on any discourse
A user reported that passkey registration failed on Discourse and meta.discourse.org when using a Nitrokey 3C, despite the key working correctly on webauthn.io. The registration attempt resulted in a 500 Internal Server Error and a NotAllowedError in the browser console, likely due to new browser requirements not yet handled by Discourse supermathie.
@keegan identified the issue and deployed an initial fix to address the registration timeout error. However, the user noted that while registration succeeded, login attempts still returned a 500 error. Debugging revealed a NoMethodError regarding the hash_function for EdDSA algorithms in the authentication service supermathie. A second fix was subsequently pushed to resolve this authentication bug keegan. The user confirmed that both passkey registration and login now work correctly, and the Nitrokey also functions properly for 2FA agr.
When using hardware which I do not own, I want to use a hardware key instead of putting my password. I got a nitrokey 3C for that purpose.
Registration on discourse fails. Also here on meta.discourse.org
p.s. Registering the key as second factor worked in a linux (debian) + chromium, but not when I try to log in.
What browser are you using?
What’s the error you get?
Are there any additional details in the dev console?
this is on debian chromium (and on ubuntu firefox the same; also the same on firefox nightly (snap) on debian )
After pressing the button on the key
‘The passkey registration process either timed out, was cancelled or is not allowed.’
Error is not helpful; nothing special on the console.
The request to https://meta.discourse.org/u/register_passkey.json gives http 500 with {“status”:500,“error”:“Internal Server Error”} payload.
Would the request data help?
id=owBYLgKCahnu_YBKKDAaTdK7LOlDFzwJ9kJPvXfntmdfbyOzs35ddeOM0KnNqHiu6bwBTLu17fF2A7QkNfCE5wJQPdOrG5MIB-9Hek6KoX4wcA
rawId=owBYLgKCahnu/YBKKDAaTdK7LOlDFzwJ9kJPvXfntmdfbyOzs35ddeOM0KnNqHiu6bwBTLu17fF2A7QkNfCE5wJQPdOrG5MIB+9Hek6KoX4wcA==
type=public-key
attestation=o2NmbXRkbm9uZWdhdHRTdG10oGhhdXRoRGF0YVjB06zu7aykTbz9dy22doBbDg8EboPkWBAWR4JLQn8z1TTFAAAAewAAAAAAAAAAAAAAAAAAAAAAUqMAWC4CgmoZ7v2ASigwGk3SuyzpQxc8CfZCT71357ZnX28js7N+XXXjjNCpzah4rum8AUy7te3xdgO0JDXwhOcCUD3TqxuTCAfvR3pOiqF+MHCkAQEDJyAGIVggy/MDuHan5fRjuKIQp7zkGku7P6p/8s2B4kfectFHcF6ha2htYWMtc2VjcmV09A==
clientData=eyJ0eXBlIjoid2ViYXV0aG4uY3JlYXRlIiwiY2hhbGxlbmdlIjoiTmpRMVpUazJaVE00WlRRNE1UZGxOamd3TVdJNE5XVm1ZV1F5TkRObE1EVmlZek0zTURkbU1qZzJPR1V6TnpRd05HUmxZamRrTVdRMk1tWTEiLCJvcmlnaW4iOiJodHRwczovL21ldGEuZGlzY291cnNlLm9yZyIsImNyb3NzT3JpZ2luIjpmYWxzZX0=
name=Main Passkey
Does it work on https://webauthn.io/ ?
yes, registering and authenticating
I just tried registering a new U2F key here on meta and I’m seeing this error in the console which probably explains it:
NotAllowedError: The operation either timed out or was not allowed.
  See: https://www.w3.org/TR/webauthn-2/#sctn-privacy-considerations-client.
I dont get the error description at w3.org ; So it is the implementation broken? I don’t seem to get the error in the console, so anything I can contribute?
We’ll need to look at this - I think browsers have implemented additional requirements (as noted in the link) since we first developed this.
Thanks @agr for identifying this issue, I’ve pushed out a fix here:
https://github.com/discourse/discourse/pull/38266
Updating your Discourse to the latest version should now resolve the issue, but if you still encounter any issues please do let us know
Registering worked fine. That was fast :slight_smile:
But login / auth.js gives me a 500 response
Confirmed; I see:
NoMethodError (undefined method 'hash_function' for an instance of COSE::Algorithm::EdDSA)
 lib/discourse_webauthn/authentication_service.rb:99:in 'DiscourseWebauthn::AuthenticationService#authenticate_security_key'
 app/controllers/session_controller.rb:399:in 'SessionController#passkey_login'
 app/controllers/application_controller.rb:443:in 'block in ApplicationController#with_resolved_locale'
 app/controllers/application_controller.rb:443:in 'ApplicationController#with_resolved_locale'
 app/controllers/application_controller.rb:1089:in 'ApplicationController#ensure_dont_cache_page'
 lib/middleware/omniauth_bypass_middleware.rb:35:in 'Middleware::OmniauthBypassMiddleware#call'
 lib/middleware/crawler_hooks.rb:11:in 'Middleware::CrawlerHooks#call'
 lib/content_security_policy/middleware.rb:12:in 'ContentSecurityPolicy::Middleware#call'
 lib/middleware/anonymous_cache.rb:420:in 'Middleware::AnonymousCache#call'
 lib/middleware/csp_script_nonce_injector.rb:12:in 'Middleware::CspScriptNonceInjector#call'
 config/initializers/008-rack-cors.rb:26:in 'Discourse::Cors#call'
 lib/middleware/default_headers.rb:13:in 'Middleware::DefaultHeaders#call'
 config/initializers/100-quiet_logger.rb:20:in 'DiscourseRackQuietAssetsLogger#call'
 config/initializers/100-silence_logger.rb:29:in 'SilenceLogger#call'
 lib/middleware/enforce_hostname.rb:23:in 'Middleware::EnforceHostname#call'
 lib/middleware/request_tracker.rb:321:in 'Middleware::RequestTracker#call'
 lib/middleware/overload_protections.rb:22:in 'Middleware::OverloadProtections#call'
 lib/middleware/processing_request.rb:14:in 'Middleware::ProcessingRequest#call'
in the logs when I try to use my Solo 2
Thank you for checking that @agr, I just pushed another fix:
https://github.com/discourse/discourse/pull/38328
Hopefully there shouldn’t be any more issues :crossed_fingers:, but please do let me know if you still encounter any issues!
Thanks for the fast fixing. I also tried using the nitrokey for 2FA and it worked both for registration and login there. Really great!!
This topic was automatically closed after 9 days. New replies are no longer allowed.
