開発インスタンスを開始できません-- renice: 優先度の設定に失敗しました
この開発インスタンスを最後に起動してから何が変わったのか分かりませんが、今はこのように失敗しています。
Sidekiq client with Sidekiq::RedisConnection::RedisAdapter options {:host=>"localhost", :port=>6379, :namespace=>"sidekiq"}
I, [2023-05-17T13:31:56.328911 #1103707]  INFO -- : worker=0 ready
I, [2023-05-17T13:31:56.330855 #1103710]  INFO -- : worker=1 ready
Loading Sidekiq in process id 1103706
/home/pfaffman/src/discourse-repos/discourse/lib/discourse.rb:137:in `exec': renice: failed to set priority for 1103706 (process ID): Permission denied
/home/pfaffman/src/discourse-repos/discourse/lib/discourse.rb:171:in `execute_command'
/home/pfaffman/src/discourse-repos/discourse/lib/discourse.rb:33:in `execute_command'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/sidekiq.rb:51:in `after_fork'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:155:in `block in run'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:151:in `fork'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:151:in `run'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:146:in `start'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:14:in `block in start'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:14:in `times'
/home/pfaffman/src/discourse-repos/discourse/lib/demon/base.rb:14:in `start'
/home/pfaffman/src/discourse-repos/discourse/config/unicorn.conf.rb:89:in `block in reload'
/home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:541:in `spawn_missing_workers'
/home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
/home/pfaffman/.asdf/installs/ruby/3.2.2/lib/ruby/gems/3.2.0/gems/unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/home/pfaffman/src/discourse-repos/discourse/bin/unicorn:96:in `load'
/home/pfaffman/src/discourse-repos/discourse/bin/unicorn:96:in `block in <main>'
/home/pfaffman/src/discourse-repos/discourse/bin/unicorn:95:in `fork'
/home/pfaffman/src/discourse-repos/discourse/bin/unicorn:95:in `<main>'
I, [2023-05-17T13:31:56.356176 #1103713]  INFO -- : worker=2 ready
E, [2023-05-17T13:31:56.452446 #1103437] ERROR -- : reaped #<Process::Status: pid 1103706 exit 1> worker=unknown
Detected dead worker 1103706, restarting...
そして、思いつく唯一の他のことは再起動でした。:shrimp: (肩をすくめる絵文字が見当たらないのですが、再起動したばかりなのに。新しいFont Awesomeアイコンを試そうとしているのでしょうか。なので、エビをここに置きます。)
この点については、まだ混乱しています。lib/demon/sidekiq.rb のこの行をコメントアウトしました。
     #Discourse::Utils.execute_command("renice", "-n", "5", "-p", Process.pid.to_s)
その行は4年間そこにあり、前回これを起動したときは機能していました。何が変わったのか分かりません。カーネルのアップグレードでしょうか?しかし、それも意味が通りません。
コンテナイメージの更新により、reniceなどのユーティリティが更新された可能性があります。あるいは、たとえば異なるプロセスで異なる方法でUIDが使用されている場合、コンテナ内の何らかのポリシー更新が妨げになっている可能性もあります。または、ベースの優先度が変更され、reniceが現在、増加できない優先度を上げようとしている可能性もあります。
これはLinuxのdevインスタンス用で、コンテナ内ではありません。私だけというのが奇妙に思えますが、私はしばしば他の誰も思いつかないような、ばかげたことをすることができます。
すみません、開発インスタンスの経験がありません。
私もです。数時間前にローカルのKubernetesで同じ問題を見つけました。
E, [2023-07-27T13:09:27.525053 #74] ERROR -- : reaped #<Process::Status: pid 456 exit 1> worker=unknown
Detected dead worker 456, restarting...
/var/www/discourse/lib/discourse.rb:137:in `exec': renice: failed to set priority for 483 (process ID): Permission denied
/var/www/discourse/lib/discourse.rb:171:in `execute_command'
/var/www/discourse/lib/discourse.rb:33:in `execute_command'
/var/www/discourse/lib/demon/sidekiq.rb:51:in `after_fork'
/var/www/discourse/lib/demon/base.rb:155:in `block in run'
/var/www/discourse/lib/demon/base.rb:151:in `fork'
/var/www/discourse/lib/demon/base.rb:151:in `run'
/var/www/discourse/lib/demon/base.rb:146:in `start'
/var/www/discourse/lib/demon/base.rb:132:in `ensure_running'
/var/www/discourse/lib/demon/base.rb:31:in `block in ensure_running'
/var/www/discourse/lib/demon/base.rb:31:in `each'
/var/www/discourse/lib/demon/base.rb:31:in `ensure_running'
config/unicorn.conf.rb:243:in `master_sleep'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/lib/unicorn/http_server.rb:295:in `join'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
