Hi every one, Im newbie.
I set up the Discourse under the IP http://128.199.222.14/.
But when i upload image, the image url change to the picture below and it can not display?
Can all you guys can help me to fix that.
I sovled that: Change http://128.199.222.14/ to 128.199.222.14 in app.yml
I will have a look on your site… I’m the user Nathanielmattock.
Okay i will active you because i did not set up email sending yet.
Hmm… What service do you use to host your data?
I use digital ocean.
The URL you upload is
http://128.199.222.14//uploads/default/original/1X/9a7032754d4a24aa23222a5961753a0bed74ffb5.jpg
It’s work but in my site it’s converted to ‘//http://128.199.222.14//uploads/default/original/1X/9a7032754d4a24aa23222a5961753a0bed74ffb5.jpg’
I dont know why it added more two slashes before the origin URL.
I think i will rebuild again and set IP just is 128.199.222.14
I might need the admin or at least moderator status to view some of the setup, unless someone that does support can…
Steven
8
I think it could be an error in the file app.yml
Line ~57 you should have
DISCOURSE_HOSTNAME: '128.199.222.14'
Nothing more
Okay it’s exactly. I finish fixed it.
I finished that. Thanks for your help.
