Category colours
As problems to have go, this isn’t a big one at all, but it’s driving me nuts nonetheless.
I am trying to change our forum’s categories. I have renamed the existing ones, and need to create a couple more.
When I create a new category the badge colour defualts to this horrible brown colour that looks like something on the bottom of your shoe. There is no option to select or change this while creating the category.
Any ideas?? I know it’s not a big problem, but I don’t want our forum to be overrun with brown.
5136
Yes, the ‘Background Colour’ in the image above is the colour selector for the category. This relates to the colour of this line and to the button / bullet used on the listing
Try selecting one of the available colours. You can also add more colours in the Admin Settings
good luck!
Update: example:
「いいね!」 4
Ahhh you’re a genius, and I’m really silly. Thank you!
I am quite certain that neither of those things is true :wink:
「いいね!」 6
このトピックは2424日後に自動的に閉じられました。返信はもう許可されていません。
