Hello, just a quick question. It’s possible to edit SMTP email options on a working forum?
Rebuild command will wipe all forum content (threads, posts, users, design)? in the case that I edit app.yml
Thanks.
Changing SMTP settings in a working Discourse forum is possible without losing any content. According to justin, rebuilding the app container will not destroy any forum content, only stopping and restarting the app. To change SMTP settings, edit the containers/app.yml file and then run ./launcher rebuild app slackmoehrle or simply ./launcher destroy app && ./launcher start app Stephen.
If switching to Mailgun, the SMTP configuration process is similar to Sendinblue, but may require additional steps such as configuring DNS/MX records. A general guide to setting up Mailgun can be found here justin.
Some users question why SMTP settings are not an admin setting, as they can change over time kratos, but the reason behind this design decision is unclear.
Thanks.
Rebuild will not destroy any forum content as that’s stored in a persistent database file. It will stop/rebuild/start the app container, however, so your site will be down during the rebuild time.
Thank you @justin, if I decide to use Mailgun is the SMTP configuration similar to in Sendinblue?
In Sendinblue had to register, confirm. Go to Transactional emails, you see SMTP details like server, port, user and password. Used that information in Discourse installation and everything worked fine.
Or there’s additional configuration within Mailgun? Like configuring DNS/MX records?
Thanks.
This howto gives a general understanding of the MailGun setup process. While it may not be the same for using Digital Ocean as a DNS provider, the general steps are very similar.
in containers/app.yml you can change these settings. Then ./launcher rebuild app
You will have to go to the directory where you cloned the Official Discourse Docker image.
If you followed the guidelines and typed the suggested directory /var/discourse when cloning the repository
git clone https://github.com/discourse/discourse_docker.git /var/discourse
then you will have to go to /var/discourse to run the rebuild app command. Otherwise, go to the different directory you chose.
cd is a command to change the current directory.
To run the rebuild app command if it’s located in the /var/discourse directory, type the following:
cd /var/discourse
Or if using another directory, type
cd <your chosen directory>
It’s not necessary to rebuild after changing SMTP details in the app.yml.
Will suffice.
I don’t understand why is this not an admin setting. SMTP settings aren’t set in stone and can change overtime.
Is this correct?
thanks a lot ,you are right ,you save me
Knowing Discourse as I do, there will be a very genuine and valid reason for this ![]()
Does anyone know what that reason might be? ![]()
