Cambia posizione di archiviazione
I initially installed Discourse on a small server with limited storage capacity and now I’m running out of space. Long term, I will end up moving to a new server. Short term, is it possible to relocate my current storage to a file server? It’s on the same local network as the Discourse server.
Sure @jomaxro can maybe point you to a relevant howto, if we do not have one, we should.
We don’t appear to have a specific howto for this, but it should be fairly simple (just moving the data to a new location and changing two lines in the app.yml). I’m going to do some testing and then I’ll write this up.
Thank you. That would be great!
This should do it:
