Change Discourse install storage location
Need to move your Discourse install to another (local) directory? Let’s get started!
Configure new directory
Ensure the new directory is properly mounted/connected as needed. Then create the folder where Discourse will live.
cd /new/discourse/location
mkdir -p shared/standalone
Copy existing files to new location
:warning: From this point forward your site will be down.
Stop the container to ensure no changes to the files are made during the transfer.
cd /var/discourse
./launcher stop app
Copy files to new location
rsync -avzh /var/discourse/shared/standalone/ /new/discourse/location/shared/standalone
Update app.yml and rebuild
Modify your app.yml so Discourse runs from the new location.
Current configuration:
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
Updated configuration:
volumes:
  - volume:
      host: /new/discourse/location/shared/standalone
      guest: /shared
  - volume:
      host: /new/discourse/location/shared/standalone/log/var-log
      guest: /var/log
Rebuild Discourse
cd /var/discourse
sudo ./launcher rebuild app
:white_check_mark: Your site will now be back up.
Test changes
Open your site and confirm everything still looks OK. Ensure that all content (including uploads) is still displaying properly.
Delete files from old location
Once you’re happy everything is working, delete the old Discourse files to regain space.
cd /var/discourse
sudo rm -r shared/standalone
