Hi all,
I find that some Chinese words cannot be searched. I don’t know why. Any idea for that?
The screenshot below comes from this site. You can view it from https://meta.discourse.org/t/discourse/6780?source_topic_id=13287
Hi all,
You have to enable search tokenize chinese japanese korean in site settings and rebuild the search index by editing the post or something.
This should be enabled by default for you in site settings if you have Chinese locale selected.
Thanks Sam. I’m not sure how to rebuild the search index, I will do some research on it. Thanks
If memory serves:
cd /var/discourse
./launcher enter app
rake search:reindex
Thanks Stephen. Do you know how to do it under development environment?
You can run rake from ./bin/docker
I can’t be more specific without details of your dev environment install.
It still doesn’t work on my dirsource.
I find an example from this site:
You can find some Chinese words from the topic above, but if you search some of these words, it shows no results.
Going by the text as it appears in the screen captures, it looks like missed
@fantasticfears any tips here? Is the segmenter broken here?
Do you enable the search tokenize chinese japanese korean? Or do you set default locale as zh_CN? Meta probably didn’t enable those settings. Mind trying something here? https://master1.discoursecn.org/
@sam Segmenter works for me. It should be something else.
I tried some words on your site. It still doesn’t work
It can be seen from the screenshot below that the provided results do not include the current topic that I was viewing, but it should include. It cannot cover all correct results.
I’m not really sure which is broken since both text come back with expected segmentation.
Can you update cppjieba_rb to 0.3.3? @sam
I am pasting some missed words here. If you copy them and search for them in Discourse, you will find that the expected search results are missing.
For this site: (the results should include this page: https://meta.discourse.org/t/discourse/6780?source_topic_id=13287)
Guide Release
For Erick Guan’s site (https://master1.discoursecn.org/)
Restart Server (search results should include: https://meta.discoursecn.org/t/topic/2510)
