Hi,
The current discourse forum can not search Chinese anymore. Can you please take a look at http://chinese.discourse.mcneel.com ?
Thanks,
Kelvin
Hi,
Thanks,
Kelvin
Are your problems similar to this topic, or is search completely broken?
Ahh, I am not sure this is a bug, I think its cause min search term length in site settings is set to the default 3.
Try reducing it down to 1 or 2 for a Chinese site.
@Mittineague, no, it’s a different problem.
@sam, changing “min search term length” to 2 solved the problem.
Thanks,
Kelvin
