Rebuilding latest fails with this error:
chown: cannot dereference '/var/www/discourse/public/fonts': No such file or directory
This is still the case… It’s not something that can be fixed without the container being up!
Are you on the default release channel ?
I follow tests-passed on this one.
I started the base image without bootstrapping and the folder is in there:
root@c58c37ab127f:/var/www/discourse/public# ls -lah fonts
lrwxrwxrwx 1 root root 90 Nov 25 22:29 fonts -> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/discourse-fonts-0.0.5/vendor/assets/fonts
Also just did a rebuild on the default release channel and it works fine
Trying to rebuild after removing a suspicious volume (vendor cache)… There’s not much else I can think of.
Do you have a pinned base image in the app.yml?
Not sure what that is… But for sure the volume was the culprit.
Thank you @falco! I think this topic can be closed.
