Chrome / Chromium bug: SSL-certificaten tonen onjuiste (verlopen) datums
A bug in Chrome/Chromium causes SSL certificates to display incorrect (expired) dates. Users report that the certificate shown in the browser differs between normal and incognito modes, and the correct certificate only appears when devtools are open. After closing devtools and refreshing, the expired certificate reappears. The issue has been confirmed by the user, who verified that the correct certificates are served by the server. The bug is present in Chromium Version 85.0.4183.83 on Arch Linux and affects Windows as well. It has been reported to the Chromium bug tracker as issue #1126113, which is a duplicate of an existing 4-year-old issue.
We have identified a bug in Chrome / Chromium that multiple hosted customers of ours have asked us about where viewing the certificate shows an incorrect expiry date:
If I open a normal Chromium window and Incognito side-by-side, the browsers report different certificates being served:
If I open the devtools and refresh, I see the correct certificate:
but then if I close the tools and refresh, I see the old certificate!
On our end, we’ve confirmed that the correct certificates are being served, so this problem seems to be entirely within Chrome/Chromium.
Verified present on:
  • Chromium Version 85.0.4183.83 (Official Build) Arch Linux (64-bit)
On Windows, you might see a valid certificate, but if you inspect it it shows as being expired:
Reported to the Chromium bug tracker as issue #1126113.
FWIW, the Chromium team has noted this is a duplicate of an existing 4-year old issue.
