Client does not have permissions to send as this sender
AI 生成的摘要
The user ric79 is experiencing an issue with sending emails from their Discourse instance, receiving the error “Client does not have permissions to send as this sender.” They have provided their app.yml and discourse.conf configurations, as well as a similar GitLab configuration for comparison.
2 fefrei suggests that the error is coming from the SMTP server, which is rejecting emails due to the FROM address used by Discourse. They recommend checking the notification email site setting in Admin → Settings and attempting to send an email from this address using the provided SMTP credentials.
ric79 confirms that this solution works, modifying the notification email setting to use the correct email address, which resolves the issue.
Hello,
I’m not able to send email. The admin email has been activated manually.
When I try to send an email a get “Client does not have permissions to send as this sender”
Here there is my app.yml config:
DISCOURSE_SMTP_ADDRESS: “smtp . company . it”
DISCOURSE_SMTP_PORT: 25
DISCOURSE_SMTP_DOMAIN: “company . it”
DISCOURSE_SMTP_USER_NAME: “COMPANY\\XX021885”
DISCOURSE_SMTP_PASSWORD: “Aaaaaaaa-aa8”
DISCOURSE_SMTP_AUTHENTICATION: “login”
DISCOURSE_SMTP_ENABLE_START_TLS: true
DISCOURSE_SMTP_TLS: false
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: false
The discourse.conf in app contains:
smtp_user_name = COMPANY\XX021885
smtp_enable_start_tls = true
developer_emails = email@company.it
smtp_port = 25
smtp_password = Aaaaaaaa-aa8
smtp_address = smtp . company . it
smtp_tls = false
smtp_openssl_verify_mode = false
smtp_authentication = login
smtp_domain = company . it
Additional info. This my my gitlab configuration for rails, which is very similar:
gitlab_rails[‘smtp_enable’] = true
gitlab_rails[‘smtp_address’] = “smtp . company . it”
gitlab_rails[‘smtp_port’] = 25
gitlab_rails[‘smtp_user_name’] = “COMPANY\XX021885”
gitlab_rails[‘smtp_password’] = “Aaaaaaaa-aa8”
gitlab_rails[‘smtp_domain’] = “company . it”
gitlab_rails[‘smtp_authentication’] = “login”
gitlab_rails[‘smtp_enable_starttls_auto’] = true
gitlab_rails[‘smtp_tls’] = false
gitlab_rails[‘smtp_openssl_verify_mode’] = ‘none’
gitlab_rails[‘smtp_ca_path’] = “/etc/ssl/certs”
gitlab_rails[‘smtp_ca_file’] = “/etc/ssl/certs/ca-certificates.crt”
I’ve tryied to run the test email script from console, but I get error
root@discourse-app:/var/www/discourse/script# ruby test_email_settings.rb
/usr/local/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in require': cannot load such file -- action_mailer (LoadError) from /usr/local/lib/ruby/2.4.0/rubygems/core_ext/kernel_require.rb:55:in require’
from test_email_settings.rb:3:in `’
I need help, definetely!
Thanks, Riccardo
PS: I added spaces in code examples just because the “2 links policy” for posting here for the first time in discourse
This error message appears to be coming from your SMTP server, which rejects Discourse’s emails because of the FROM address Discourse uses.
Please look at the site setting notification email (in Admin → Settings). Can you manually send an email from this address via the SMTP credentials you provided in app.yml?
Thanks, you are right.
I modified ADMIN | Settings | notification email with the right email to user (previously noreply@…) and now it is working
Riccardo
