Bibliofile
(Bibliofile)
October 14, 2016, 10:04pm
1
There is an issue with code blocks within details tags. I won’t even try to guess why this is broken. If you put the following code into a post, instead of the two distinct details blocks with code blocks within them that you would expect, you get a single details block with stripped HTML inside
<details><summary>Summary</summary>
```HTML
<script>alert("Text");</script>
</details>
<details><summary>Summary2</summary>
```HTML
<script>alert("Text"); </script>
</details>
Example:
Summary
Summary2
jomaxro
(Joshua Rosenfeld)
October 14, 2016, 10:09pm
The issue isn’t with details tags, it’s with the language you listed for the code block. HTML isn’t a valid language. You need to use html.
This works:
```html
</details>
```html
</details>
Summary
Summary2
Bibliofile
(Bibliofile)
October 14, 2016, 10:46pm
3
Thank you! No wonder I couldn’t seem to reproduce this with any other language…
