Code formatting bug
A user, Denis_Frosty_Andreyc, reported a bug with code formatting in the discussion “Code formatting bug”. They encountered issues when trying to combine numbered lists and code formatting. gerhard provided a solution, suggesting the use of 3 additional spaces within lists to manually indent the code.
gerhard also helped Denis_Frosty_Andreyc remove syntax highlighting by adding text after the backticks or indenting the code snippet with spaces.
Dennis_Frosty_Andreyc expressed gratitude for the assistance. codinghorror recommended learning more about Markdown formatting, providing a link to the CommonMark help page: http://commonmark.org/help
I noticed that I can not use formatting for the code. Can someone help with the solution?
If I use Numbered list, then I can not use the formatting for the code.
Example:
  1. Test message
    java -Dfile.encoding=UTF-8 -jar forge-1.8-11.14.4.1577-universal.jar
    pause
  2. Test message
But everything works separately.
pause
The toolbar button doesn’t use the right indentation within lists. You’ll need to do it manually.
You need to use 3 additional spaces within lists.
1. Test message
   pause
       pause
2. Test message
Which looks like this:
  1. Test message
    pause
    pause
  2. Test message
Thanks for the answer. Now everything works perfectly.
One more question. Can I remove cyan color for java and for 1.8-11.14.4.1577?
Sure. Add text after the backticks or indent the code snippet with spaces.
```text
pause
Awesome. Tnx for help :heart:
You may wish to learn more about Markdown formatting, see Markdown Reference
