Code fences inside a list render as one line
While testing another bug, I posted this text to try.discourse.org:
problem_post.txt (2.5 KB)
The editor preview shows line breaks in the code block, but the post itself renders without the line breaks.
This can happens when an invalid language keyword is used, let’s see
line above
size(600, 400);
println("width " + width);
println("height " + height);
versus
line above
size(600, 400);
line above
``` bleh
size(600, 400);
versus
line above
size(600, 400);
The code seems to work fine when it is not nested under a bullet.
  1. Some list
    size(100,100);
    ellipse(x,y,100,100);
  2. Another list item
versus…
size(100,100);
It’s the backtick code blocks inside list which are not standardized across implementations (the preview and output differing seems like a real bug though). But you can use indented code blocks as a workaround until Discourse switches to markdown-it (which supports what you are trying to do).
1. first
        size(x, y);
        print(1);
2. second
        size(x, y);
        print(1);
3. third
4. and so on
  1. first
     size(x, y);
     print(1);
  2. second
     size(x, y);
     print(1);
  3. third
  4. and so on
Thanks I’ve fixed this in master (it’s currently being deployed):
