Someone compained that code highlighting isn’t working on their site. I’ve replicated the issue on mine. The issue seems to be that the CDN is blocked by CORS policy:
I fixed the problem by adding js to the “add cors header” setting on the cors page:
If enabled, bunny.net will automatically add CORS headers (Cross-Origin Resource Sharing) to all requests to files with extensions from the list.
This post is to document it in case someone else has an issue with a bunny.net CDN and to make sure that I understand this.
I believe there is (or used to be) a setting in bunny which added js to cors? I (for some reason) have js added to cors for all my bunny.net resources but I don’t recall adding them myself. Is it a fairly new site?
But even before that change, you likely would have had some issues with things like custom Fonts (which also require CORS headers for cross-origin requests).
In theory, Discourse itself should be adding the CORS header to CDN responses. If it’s not, that probably means your CDN is not setting the CDN hostname (i.e. not the forum hostname) in the Host header or the X-Forwarded-Host header.
That said, adding the headers via the CDN config likely achieves the same thing
