Kleurenschema's zijn nu kleurenpaletten
Discourse has updated its terminology, replacing “color scheme” with “color palette” across the interface to improve consistency and align with modern design language. The change affects the admin area, customization settings, and UI elements, though functionality remains unchanged. While the new term should be used in documentation and guides, some older references to “color scheme” may persist as updates are rolled out. Developers should note that internal code references like variable names will retain “scheme” for technical stability. hugh announced the change, and Moin inquired about updating Meta documentation, referencing a stalled PR. david acknowledged the oversight and welcomed a new PR to update the documentation without altering the internal ‘id’ of the doc.
We’ve updated the terminology in Discourse’s interface to improve consistency across the platform. What was previously called a “color scheme” is now referred to as a “color palette” throughout the user interface.
What’s Changed
  • The term “color scheme” has been replaced with “color palette” across the Discourse interface.
  • This change affects what you’ll see in the admin area, customization settings, and other UI elements.
  • The functionality remains exactly the same - only the terminology has changed.
What to Expect
  • If you’re writing documentation or guides about Discourse, please use “color palette” going forward.
  • You may still see references to “color scheme” in some documentation as we gradually update all materials.
  • For developers: References to “scheme” will remain in the codebase (variable names, function names, etc.) for technical stability.
Why This Change?
This update brings more consistency to our interface language and aligns with modern design terminology. While this is a small change, we believe that consistent terminology makes the platform more intuitive to use.
Questions?
If you have any questions about this change, or notice any areas where it has not been appropriately updated, please reply below.
Are there plans to update the documentation on Meta to use the “new” wording? I found this PR: Change scheme to palette by hlashbrooke · Pull Request #25 · discourse/discourse-developer-docs · GitHub, but it was created a while ago and seems to have conflicts now.
Looks like we dropped the ball on that one. I closed it, but pr-welcome on a fresh one (as long as it doesn’t change the internal ‘id’ of the doc)
