העמודה bookmarks.topic_id אינה קיימת
I’m getting “The software powering this discussion forum encountered an unexpected problem” on topics with bookmarks. Reloading each topic after the error makes it go away.
I’m on the latest build: 2.8.0.beta10 (6b6c0fef4c)
Are you using any plugins? Maybe try safe_mode.
Or perhaps somehow your database didn’t get migrated on an upgrade?
Thanks, Jay.
I’ve gone into all my existing bookmarks and besides the 2 errors I saw this morning, no others came up (in normal or safe mode).
I might rebuild from the server tomorrow, but it seems like it was a temporary error. :man_shrugging:
How did the rebuild go?
No issues after the rebuild, but I’m not sure if it’s because a rebuild was needed or because I didn’t have enough old unvisited bookmarked topics to test. :man_shrugging:
UPDATE: @sam Actually, I did run into an issue with missing avatar profile pics
I’ve run into the same error on a saved report I had created using the plugin for Data Explorer.
PG::UndefinedColumn: ERROR:  column "topic_id" does not exist
LINE 46: topic_id,
I looked at the table and topic_id isn’t on the columns list anymore. I’m not an administrator, so I’m not sure what action I can take to try and fix this, or why it would disappear in the first place.
