Hello, when entering a character (for example '), it is automatically replaced with a >
Example
I did the test becomes I>did the test
Example
Can you share the exact text you used to yield that result? Does it occur here on Meta?
No, this does not happen on Meta but on my self-hosted Discourse forum.
Here is an example in standard mode:
In rich mode:
The text is:
Alright, I’ve reproduced the issue. I’ll talk to the admin.
Does this occur in safe mode on your forum?
This is an eager typographer replacement; it happens here too, but the default markdown_typographer_quotation_marks are different on a non-French instance.
You can disable enable_markdown_typographer or set the quotation marks site setting to a different default.
That said, I feel there are some quick wins we can make to improve this experience. We’ll look into those. The site settings are immediate alternatives.
I’m having the same issue now, it’s quite annoying! I will disable the setting – given the amount of apostrophes we use in French it makes writing a complete nightmare…
ETA: I’ll miss the emdash replacement; also, I’ve honestly never really seen that “single quote replacement” used in real life (at least not that I can remember), and having the apostrophe auto-replace to that is just impossible in French. We have like 3 apostrophes per sentence on average ![]()
We have since removed the auto-conversion on the rich editor:
The conversion may still happen at posting (cooking) time (if quotes are paired, site settings are enabled, and other conditions are met), but it won’t do it while typing anymore.
This topic was automatically closed after 3 days. New replies are no longer allowed.
