צפיות בעמודים מקובצות: להחריג את Crawl ה-uptime מהדוח מבלי לחסום?
סיכום מבוסס בינה מלאכותית
The discussion revolves around excluding the Uptime Kuma crawler from consolidated pageview reports without blocking it entirely. ToddZ seeks a way to exclude the Uptime Kuma user agent from pageview counts while still monitoring other traffic spikes. pfaffman suggests using /srv/status as a non-tracking endpoint, which ToddZ confirms works. The conversation also touches on UptimeRobot, which appears to be automatically excluded from reports, and mentions a potential plugin, discourse-betterstatus, for more robust health checks pfaffman, though its current functionality is uncertain.
So I’ve set up an instance of Uptime Kuma to monitor my forum, and now, of course, the crawler graph has skyrocketed. I know I can toggle crawlers entirely from the display by clicking “Crawlers” in the graph key, but I’d like to just exclude the “Uptime-Kuma” user agent behind the scenes and still watch for other spikes.
(@pfaffman – you’ve brought this up before – did you happen to come up with anything?)
You can hit /srv/status and that doesn’t get counted. You might also be able to hit something like /t/-/123.json and then look for title or something like that. I think that won’t count as a pageview.
Thank you Jay! I’ve added that to the tracking URL, and it appears to have stopped adding to the crawler count.
I forgot to mention that prior to this I’ve had Uptime Robot in place for a long time, just tracking the base URL.
Interestingly, YTD Discourse has reported just 1 hit from Mozilla/5.0+(compatible; UptimeRobot/2.0; http://www.uptimerobot.com/).
I wonder if some uptime crawlers are automatically excluded from reporting..? :thinking:
Glad to hear it.
There are some cases where /srv/status can say ‘ok’ when it’s not so OK. I think there’s a communiteq plugin that catches some more cases, but I couldn’t find it in 10 seconds.
I don’t see UptimeRobot in the source. And I’m pretty sure that I remember UptimeRobot hits counting at some time in the past, but I’ve been using /srv/status for a long time.
I forgot about that !!! And I had to look for it for over 10 minutes as well.
It’s here GitHub - communiteq/discourse-betterstatus · GitHub and TBH I have no idea if it still works. If it does, it will perform a very rudimentary check to see if Redis and Postgres are working.
