Control which comments are embedded?
In a discussion titled “Control which comments are embedded?”, carstenwawer asks if it’s possible to selectively display only certain comments (e.g., most liked or moderated) when embedding Discourse comments on external sites, especially to avoid overwhelming pages with hundreds of comments. eviltrout clarifies that while there’s no way to pick specific comments, a site setting (embed post limit) caps the total number shown (default: 100). carstenwawer considers building a custom embed solution to show “interesting” comments, prompting riking to reference the wp-discourse plugin, which renders comments server-side. carstenwawer prefers client-side rendering for caching efficiency, sparking a debate with meglio about whether client-side caching is truly more efficient — carstenwawer defends it in the context of Varnish and Redis caching layers. Later, sam suggests implementing a feature similar to what BBS uses — displaying only staff-liked comments — and invites carstenwawer to submit a PR. simon revives the thread years later, noting Google now indexes embedded comments and highlighting SEO concerns; he proposes a UI option for staff to explicitly choose which comments appear, rather than relying on likes. sam distinguishes SEO from the original feature request, while simon argues the feature serves both purposes and questions Discourse’s broader strategy for comment embedding. The thread remains unresolved but highlights demand for granular comment control in embedded contexts.
Hi there!
Is there a possibilty to control which(!) Comments are displayed on an embedding Website?
If Discussion goes wild, i don’t want to display every (of eventually hunderds) comment under the underlying Webpost.
Any possibilty to achieve this?
Thanks in Advance!
Carsten
1 „Gefällt mir“
There is no way to choose specifically which comments are shown when embedding. However there is a site setting embed post limit which limits how many will be attached to any given post. The default is 100.
3 „Gefällt mir“
Thanks for your response!
Perhaps i’ll build my own embed-Code, that gets the most “interesting” reactions.
That’s what the wp-discourse Wordpress plugin does, if you need an idea for which metrics to use…
HI @riking,
but the wp-discourcse-Plugin does not load the Comments client-side, but generates the HTML on the Wordpress-Page, right?
I like the client-side-generation-approach, because it makes caching so much more efficient.
I’ll have a look at it!
Thanks!
Client-side caching in browser isn’t more edficient than server-side caching. For instance, when cache is used server-side, you deliver the HTML generated immediately. If caching client-side in browser, you’ll have tonread the cache and update your HTML, so it may not look instant to the user.
Hi @meglio,
thanks for your input, but i doubt you can say that…
We are working with varnish-Caching in Front of the Website and I guarantee, that it makes sense in this kind of setup.
Client-Side-Handling of personalized Content is standard, if you work with caching-proxys…
Have a good Day!
Carsten
May you elaborate, please: which data and where cached exactly.
We got several Caching-Layers(Varnish, a self-written REDIS-Caching-Plugin for Wordpress and more) in this project. I think it’s not ontopic to explain the whole setup here.
The point is, that in some setup, it can make a real caching-advantage, if the cached data is not altered after every new comment. And that’s what i want to accomplish amongst others.
I had a look into the discourse-code at the weekend and tend to write my own implementation of what i need in the next weeks.
Thanks for your help!
Still not clear, where would you like the comments to be cached? In browser?
I just want to cache the HTML of a Page independent from the Comments, so i dont have to invalidate Cache-Objects in Varnish for every new comment incoming.
I’m confused, sorry. When you embed Discourse comments via JS, your comments are generated client-side, AFTER the page is loaded into the user’s browser. So you’re free to cache whatever HTML your page is: it will include the JS-comments embed code, but not the comments themselves.
I haven’t learned much about the native Discourse comments embedding via JS, but that’s how js-embedding works. Unless I misunderstood your goals.
Hi @meglio,
we discussed here two possible implementations:
native discourcse-js-embed-solution: lacks a possibility to control what posts are displayed in situations where hundreds of posts are posted in a thread. you can control the number of posts, but nothing like "display only the most-liked-posts, if there are more then 30 posts in the thread. But it is client-side in the way i need it - right!
wp-discourcse-plugin: The Discourse-Plugin for Wordpress implements the Discourcse-Posts as Comments in the Wordpress-Comment-Database. The Comments are implemented (as HTML) into the corresponding HTML-Document and are not integrated Client-Side.
That makes it clear?
Carsten
Yes, thanks. So what you’re saying is that you’d like to have some caching of the comments HTML server-side in the Discourse’s WordPress plugin, so that the whole page HTML does not need to re-render with every load?
What we did for BBS probably should carry over as an option.
On BBS we display comments that were liked by staff members. I think that is a very good option to add here.
@carstenwawer perhaps do a PR for this?
6 „Gefällt mir“
Hi @sam, @carstenwawer,
Did this get implemented? If yes, can you please point me to where I should be setting it?
Ich stoße ein super altes Thema wieder hoch. Vielleicht sollte ich ein neues eröffnen?
Ich bin mir nicht sicher, wie die Dinge im Jahr 2016 waren, aber Google indexiert jetzt eingebettete Discourse-Kommentare. Sie können dies bestätigen, indem Sie nach einigen der Kommentar-Inhalte von https://blog.discourse.org/ suchen. Beachten Sie, dass Meta die Einstellung embed set canonical url nicht aktiviert hat, sodass Sie möglicherweise doppelte Ergebnisse erhalten, wenn Sie Blog-Kommentare durchsuchen, oder Sie müssen auf den Link “Weitere Ergebnisse anzeigen” auf Google klicken, um Blog-Kommentare anstelle des Meta-Posts zurückzugeben.
Meine Bedenken hierbei sind hauptsächlich SEO-bezogen. Irrelevante oder negative Kommentare können SEO schaden. Relevante Kommentare, die einen zusätzlichen Kontext zu einem Blog-Post hinzufügen, können SEO helfen: Google On The SEO Value Of User Comments On Websites.
Das WP Discourse-Plugin geht damit um, indem es eine Option “Nur von Moderatoren gelikte anzeigen” hat, um zu steuern, welche Kommentare angezeigt werden. Das Hinzufügen einer ähnlichen Funktion zu eingebetteten Kommentaren wäre unkompliziert, aber wäre es besser, ein explizites Kontrollkästchen für Mitarbeiter zu haben, um zu bestimmen, ob Kommentare in einem Blog-Post angezeigt werden oder nicht?
2 „Gefällt mir“
Das fühlt sich für mich nach einem anderen Thema an. Bei Ihnen geht es um die Optimierung von SEO. Hier geht es einfach darum, zu steuern, was angezeigt wird.
Ich nenne nur einen weiteren Grund, die im OP geforderte Funktion zu implementieren. Ich bin nicht übermäßig an SEO interessiert, aber in diesem Fall scheint es einfach zu sein.
Meine eigentliche Frage war, wie die Benutzeroberfläche für die Funktion aussehen sollte. Das WordPress-Plugin setzt voraus, dass ein Moderator einen Beitrag mit „Gefällt mir“ markiert hat: discourse/lib/filter_best_posts.rb at main · discourse/discourse · GitHub. Es wäre einfach, diese Funktionalität zu eingebetteten Kommentaren hinzuzufügen, aber es scheint nicht der ideale Weg zu sein, um zu steuern, welche Kommentare angezeigt werden.
Ich bin mir nicht sicher, wie groß das Interesse daran ist, die Verwendung von Discourse als Kommentarsystem für Websites zu fördern. Vielleicht verdient das ein eigenes Thema.
