Statut de connexion Cookie pour Discourse / Optinmonster
Im trying to figure out if it’s possible to hide a optin bar (subscribe bar/Optinmonster) for users that are logged in.
So if users are logged in they shouldn’t see the bar. I can set these values in Optinmonster (cookie name +/or cookie value)? Does any of you know the solution?
Here is a screenshot:
Thanks in advance!!!
You can hide it with CSS for logged in users, would that work for you?
Ah perfect it works :slight_smile: Thanks!
This works:
.[class] {
  display: none !important;
.anon [class] {
  display: inline !important;
Replace [class] with your own.
