評判とレベルを表示するプラグインを作成
What would you like done?
Plugin that shows reputation and level.
wrt Reputation and level on member profile
When do you need it done?
No time frame.
What is your budget, in $ USD that you can offer for this task?
We would discuss.
「いいね!」 2
This would be awesome
「いいね!」 2
Can you explain what you mean by ‘Reputation’ and ‘Level’. Level = Trust Level? Reputation is based on what? How would it be calculated?
「いいね!」 1
Yes.
Level will be Trust level.
Reputation is calculated upon factors:
1.No. of quality posts.
2.No. of likes received.
3.No of days active.
The actual calculation will be shared in private message. to whoever is ready to take the task ahead.
「いいね!」 2
Can you define “quality posts?” How is that determined vs a regular post?
I might be able to help you on this one. Feel free to hit me up at hello@procourse.co.
「いいね!」 4
I created a plugin that calculates scores from the Discourse stats.
Probably I can extended on that to make what you want. I can work on this if it’s going to be open sourced after.
@hashOK PM me if this is still available
「いいね!」 7
