Creating a plugin
Hi,
I have very little knowledge of how Discourse works but I need to create a plugin. I’ve seen the different Guides on how to create a plugin like Beginner's Guide to Creating Discourse Plugins - Part 1 or Rails plugin generator.
  1. I don’t know how to find the “plugins” directory ? I’ve looked under /var/discourse/ and /var/lib/docker/ but I can’t find the one that is used by Discourse.
  2. I don’t understand how to use the Rails plugin generator.
rails g plugin DiscourseRacoon
I’m trying to use this command but I always have this result
root@discourse:~# rails g plugin testPLugin
Usage:
  rails new APP_PATH [options]
Options:
  -r, [--ruby=PATH]                                      # Path to the Ruby binary of your choice
I’ve tried to look for answers on how those commands and on how Discourse works but I can’t find any.
I hope I’ve been clear on what I’m searching for and thanks for any answer
