Creating admin using rake admin:create
(Hammad Abbasi) #1
Hi,
I am running discourse multi-site setup, I am wondering how can i create administrator using
rake admin:create
It creates the administrator on first site.
Troubleshooting multi-site databases
(Régis Hanol) #2
You have to switch database using the RAILS_DB=<name_of_db> prefix before the command
RAILS_DB=site1 rake admin:create
(Hammad Abbasi) #3
It’s still creating admin account for first web site
(Hammad Abbasi) #4
I am also trying to connect to 2nd database manually using
su -c ‘psql discourse’ postgres
but it throws error “no password entry for user postgres”
(Hammad Abbasi) #5
Hi,
I have setup a multi-site up and running however I am unable to create admin or configure notification email for 2nd site
so i have few questions
How can i configure SiteSettings in app.yml for a) 2nd Site b) ALL SITES
  • exec: rails r “SiteSetting.notification_email=’’”
I have tried manually connecting to both databases using
sudo -u postgres psql b_discourse
but when i run select * from users ( it returns nothing )
I tried running “rake admin:create RAILS_DB=b_discourse”- but this is creating the user on first site.
I ran “SiteSetting.notification_email” command in rails console it shows email from 1st Site - is there any way i can switch database in rails console ?
(Alan Tan) #6
RAILS_DB=b_discourse rails console or RAILS_DB=b_discourse rails runner <command>
(Alan Tan) #7
Try RAILS_DB=b_discourse rake admin:create?
(Hammad Abbasi) #8
I did but didn’t work (creating on first site)
I am however able to use 2nd db using "RAILS_DB=b_discourse rails console "
Can i create an admin user or change password of existing user using this console ?
Please advice. Many Thanks for your Help
(Alan Tan) #9
Hmm I’m not sure why it isn’t working for you. I just tested locally and it works fine.
Yup you can :slight_smile:
(Hammad Abbasi) #10
Below is my app.yml for 2nd site ( First site is using default - discourse_hostname)
before_bundle_exec:
- file:
path: $home/config/multisite.yml
contents: |
secondsite:
adapter: postgresql
database: b_discourse
pool: 25
timeout: 5000
db_id: 2
host_names:
- community.mydomain.com
I just realized “RAILS_DB=b_discourse rails console” is also connecting to first database
(Alan Tan) #11
Try RAILS_DB=secondsite instead.
(Hammad Abbasi) #12
Bingo - It worked :smiley:
Thanks alot
(Régis Hanol) #13
