A critical error occurs when publishing a post to Discourse using the WP Discourse plugin with the Divi theme. The error message indicates an ArgumentCountError with Too few arguments to function ET_GB_Block_Layout::get_the_excerpt().
angus suggests that the error is coming from the Divi plugin or one of its extensions, and recommends checking for updates and reporting the issue to Elegant Themes. The error only occurs when Divi is enabled, as confirmed by oreillyc.
The WP Discourse plugin code appears in the stack trace, but angus explains that this is because post-publication code is executed in an interconnected fashion, and does not necessarily mean that WP Discourse is the source of the issue.
Using the lastest discouse and WP Discourse Wordpress plugin I get the following error when attempting to publish a post to discourse:
An error of type E_ERROR was caused in line 207 of the file /www/sociocracyforall_679/public/wp-content/themes/Divi/includes/builder/feature/gutenberg/blocks/Layout.php. Error message: Uncaught ArgumentCountError: Too few arguments to function ET_GB_Block_Layout::get_the_excerpt(), 1 passed in /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php on line 303 and exactly 2 expected in /www/sociocracyforall_679/public/wp-content/themes/Divi/includes/builder/feature/gutenberg/blocks/Layout.php:207
Stack trace: #0 /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php(303): ET_GB_Block_Layout->get_the_excerpt(‘It was yet anot…’) #1 /www/sociocracyforall_679/public/wp-includes/plugin.php(189): WP_Hook->apply_filters(‘It was yet anot…’, Array) #2 /www/sociocracyforall_679/public/wp-content/plugins/wp-discourse/lib/discourse-publish.php(271): apply_filters(‘get_the_excerpt’, ‘It was yet anot…’) #3 /www/sociocracyforall_679/public/wp-content/plugins/wp-discourse/lib/discourse-publish.php(209): WPDiscourse\DiscoursePublish\DiscoursePublish->sync_to_discourse_work(32452, ‘The day I conse…’, ’
It seems like a bug from an arguments change between versions, eh?
Hey CJ, it looks like the error is coming from the Divi plugin or one of its extensions.
Indeed, if you google ET_GB_Block_Layout you’ll see a number of other sites have the same issue (In many cases present in the HTML being scraped by google). You should check you’re running the latest version of their plugin, and perhaps report this to Elegant Themes.
The reason the WP Discourse code appears (further down, which typically means it’s not the source of the issue) in the stack trace is because whenever you click the publish button any post-publication code will be executed, in an interconnected fashion.
If there’s any exception post-publication, whatever the source, the wp discourse plugin code is likely to appear at some point in the stack trace. It doesn’t mean it’s the source of the issue though.
ArgumentCountError: Uncaught exception 'ArgumentCountError' with message 'Too few arguments to function ET_GB_Block_Layout::get_the_excerpt(), 1 passed in /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php on line 303 and exactly 2 expected' in /www/sociocracyforall_679/public/wp-content/themes/Divi/includes/builder/feature/gutenberg/blocks/Layout.php:207
in ET_GB_Block_Layout::get_the_excerpt called at /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php (303)
in WP_Hook::apply_filters called at /www/sociocracyforall_679/public/wp-includes/plugin.php (189)
in apply_filters called at /www/sociocracyforall_679/public/wp-content/plugins/wp-discourse/lib/discourse-publish.php (271)
in WPDiscourse\DiscoursePublish\DiscoursePublish::sync_to_discourse_work called at /www/sociocracyforall_679/public/wp-content/plugins/wp-discourse/lib/discourse-publish.php (209)
in WPDiscourse\DiscoursePublish\DiscoursePublish::sync_to_discourse called at /www/sociocracyforall_679/public/wp-content/plugins/wp-discourse/lib/discourse-publish.php (158)
in WPDiscourse\DiscoursePublish\DiscoursePublish::publish_post_after_save called at /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php (305)
in WP_Hook::apply_filters called at /www/sociocracyforall_679/public/wp-includes/class-wp-hook.php (327)
in WP_Hook::do_action called at /www/sociocracyforall_679/public/wp-includes/plugin.php (470)
in do_action called at /www/sociocracyforall_679/public/wp-includes/post.php (5180)
in wp_after_insert_post called at /www/sociocracyforall_679/public/wp-includes/post.php (4482)
in wp_insert_post called at /www/sociocracyforall_679/public/wp-includes/post.php (4570)
in wp_update_post called at /www/sociocracyforall_679/public/wp-admin/includes/post.php (423)
in edit_post called at /www/sociocracyforall_679/public/wp-admin/post.php (227)
