CSS لعرض عالمي متجاوب
I am trying to configure CSS for my entire site to be responsive in with i.e. for the width to adjust to the full width of the current window.
I know these entries represent brute force and are not particularly elegant. That said, it actually works well for just about every aspect of the site, including the window to create/edit a new post.
However, the actual post content itself - which appears to be in a CSS element called css.coked - remains at a fixed width no matter how I attempt to override it. What can I do so viewed posts also expand to the window size?
  • {max-width: 100% !important };
div.cooked {max-width: 100% !important };
div.cooked {width:2000 !important };
p {max-width: 100% !important };
You need to overwrite
.topic-body {
    width: calc(690px + (11px * 2));
so try
.topic-body {
    width: 100%;
However you need to think how to handle the timeline on the right using a width of 100%…
See this site as example:
Thank you
I see there are a number of other of unintended effects of the other global CSS changes so I need to rethink this or be more nuanced in the edits I make.
Yes, it’s not so simple to modify the layout widht. The elements that are impacted are many and consider that you must do a lot of work with the media queries to adapt the changes to devices of all sizes.
