Forum remove fixed width
Hi all!
I want to remove the fixed width size and replace it with a percentual value.
How can I do this? I tried so many things out but none of them worked.
Here are two images how it should be at the “homepage”.
And here inside a topic.
So who can give me a hint or directly the code for it?
I would be very grateful!
Can no one help me? Please!
By column width
First we need to redefine display: flex;:
.categories-and-latest {
    display: block;
and then, set the width:
.column.categories{
    width: 40%;
    float: left;
This is only as a sample. You may have to grab the previous div and take care of the screen width. I have no idea what will happen on mobile devices, and it will require adding more css.
Pay attention to: display: flex;. Perhaps there are difficulties in this.
Thank you!
What I’m looking for is the css selector for the default width.
I’ve tried .wrap and many others, but none worked. I got them with the inspector.
Tried using for .wrap
max-width: 100%;
and width became 100%
If I do this only the header and the footer are 100%.
Am I missing something?
EDIT:
I checked again and insert
#main > div #main-outlet {
	max-width: 90%;
	width: 90%;
but as you can see in the screenshot it gets overwritten from theme_11.scss and I don’t know why.
Try this option.
    display: block;
.wrap {
    max-width: 90%;
    width: 90%;
.categories-and-latest div.column.categories {
    width: 40%;
    float: left;
It’s the same as above, it gets overwritten from theme_11.scss.
It’s really annoying because it worked once but now not anymore.
Edit:
It’s one of the theme components, I have to figure which one.
Got it, it’s the offical “Easy responsive footer”. After removing it the site changed to 90% width.
Maybe @Johani can have a look at it because I would like to have the footer again.
Edit2:
And “Versatile Banner” is “corrupting” the width changes. Maybe @tshenry can have a look, too?
