Hi,
I have added a css which is not reflecting even though I’ve saved it. Can someone help me with this? Please go through the attached screenshot.
Thank you in advance!
The user Aditya_Shevle reported that their CSS changes were not reflecting despite saving them. keegan explained that the CSS should be placed in the CSS tab rather than the <head> section, as the CSS tab has higher priority. tynaut elaborated that styles in the <head> have lower priority and can be overridden by those in the CSS tab, and also advised checking if the theme is enabled and properly selected in the theme-component settings. Aditya_Shevle confirmed that the issue was resolved after applying the suggested changes.
Elaborating on this:
Styles in the <head> tag section can apply, but they have lower priority. If you have styles in the <head> tag section and styles in the style section, the style section will take priority and override your changes, as the head tag is loaded earlier. Later is considered more !important.
Another thing to check for is:
If this is a theme, make sure the theme is checked as Enabled.
If this is a theme-component, make sure under the theme-component settings “Include component on these themes” has your active theme selected.
@tynaut Thank you so much for the help. It perfectly working.
