rake aborted!
NoMethodError: undefined method `each_pair' for nil:NilClass
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.7.1/lib/active_support/core_ext/hash/deep_merge.rb:22:in
`deep_merge!'
/var/www/discourse/lib/js_locale_helper.rb:10:in `block in
plugin_translations'
/var/www/discourse/lib/js_locale_helper.rb:9:in `each'
/var/www/discourse/lib/js_locale_helper.rb:9:in `plugin_translations'
/var/www/discourse/lib/js_locale_helper.rb:30:in `load_translations'
/var/www/discourse/lib/js_locale_helper.rb:67:in `block in
load_translations_merged'
/var/www/discourse/lib/js_locale_helper.rb:66:in `each'
`load_translations_merged'
/var/www/discourse/lib/js_locale_helper.rb:89:in `translations_for'
/var/www/discourse/lib/js_locale_helper.rb:101:in `output_locale'
/var/www/discourse/app/assets/javascripts/locales/nl.js.erb:3:in
`_evaluate_template'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/erb_processor.rb:26:in
`call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/erb_processor.rb:13:in
`call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:75:in
`call_processor'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:57:in
`block in call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:56:in
`reverse_each'
`call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:134:in
`load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:60:in
`block in load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:317:in
`fetch_asset_from_dependency_cache'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:44:in
`load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:20:in
`block in initialize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:47:in
`load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:23:in
`block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/utils.rb:196:in
`dfs'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:24:in
`call'
`call_processor'
`reverse_each'
`call_processors'
`block in load'
`load'
`load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:66:in
`find_asset'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:73:in
`find_all_linked_assets'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:134:in
`block in find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:133:in
`each'
`find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:185:in
`compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:68:in
`block (3 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/rake/sprocketstask.rb:147:in
`with_logger'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:67:in
`block (2 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-11.2.2/exe/rake:27:in
`<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => assets:precompile
Bundling assets
I’ll have a look. Recent commit of mine broke this.
4 לייקים
Can I check what plugins do you have installed? The failing error is really odd
Looks like someone reported this and I did a dupe but:
I’m using:
discourse (9859bfb)
babble (604bbdb)
RO buttons (adds some buttons, very simple plgin)
discourse-details
discourse-feature-voting (811f5e3)
discourse-nginx-performance-report
discourse-push-notifications (c4d91a2)
discourse-solved (ed0a294)
staff-notes (d9db406)
docker_manager (a7b2562)
lazyYT
poll
roauth_strategy (our login system)
Nothing fancy.
Also note your own travis-ci fails with the same error:
https://travis-ci.org/discourse/discourse/jobs/163850017
3 לייקים
@eviltrout this has to be somehow related to the locale splitting you did
@carlokok Turns out it was blowing up due to discourse-feature-voting because it had a translation file with an incorrect locale key in it.
I also made sure we don’t blow up if the locale key cannot be found.
Thank you for reporting!
9 לייקים
