Trying to upgrade discourse to latest version, but before that I need to upgrade docker manager and
getting following exception while upgrading:
Bundled gems are installed into ./vendor/bundle.
$ bundle exec rake multisite:migrate
rake aborted!
SyntaxError: /var/www/discourse/lib/plugin/instance.rb:273: syntax error, unexpected <<
js << <<~JS
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:457:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:457:in `block in load_file'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:647:in `new_constants_in'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:456:in `load_file'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:354:in `require_or_load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:317:in `depend_on'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:233:in `require_dependency'
/var/www/discourse/lib/discourse.rb:2:in `'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:274:in `require'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:274:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.7/lib/active_support/dependencies.rb:240:in `load_dependency'
/var/www/discourse/config/application.rb:31:in `'
/var/www/discourse/config/application.rb:19:in `'
/var/www/discourse/config/application.rb:18:in `'
/var/www/discourse/Rakefile:5:in `require'
/var/www/discourse/Rakefile:5:in `'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-11.2.2/exe/rake:27:in `'
Current versions:
docker_manager(9b59950)
discourse (11e303e)
sam
(Sam Saffron)
July 22, 2016, 6:54am
Are you 100% sure you are not running any plugins except for docker_manager?
Sorry I should have included list of other plugins as well, using following plugins:
cpradio
(cpradio)
July 22, 2016, 10:24am
4
You are probably better off letting it upgrade all of them by logging into the server and running
./launcher rebuild app
Especially if you are following tests-pased, as a lot of those plugins have had changes due to recent Core changes.
eviltrout
(Robin Ward)
July 22, 2016, 5:04pm
5
The problem here is the ruby 2.3 syntax - @tgxworld told it was safe to use, but perhaps it is not?
Falco
(Falco)
July 22, 2016, 5:15pm
6
The guy isn’t running the latest docker image, the latest enforce ruby 2.3.
Yeah and I’m getting this exception while upgrading docker_manager.
Falco
(Falco)
July 22, 2016, 6:18pm
8
Doesn’t a simple:
cd/ var/discourse
git pull
works?
The docker manager isn’t used to update the launcher, and is need on the big transition upgrade (ruby, pg, nginx, etc update from earlier this month).
cpradio
(cpradio)
July 22, 2016, 6:20pm
9
That was my questioning too. In theory, I would think that would solve his issue.
tgxworld
(Alan Tan)
July 22, 2016, 11:11pm
10
Hmmm this is odd. I added a check to make docker manager raise an error and make the user rebuild if Ruby is not 2.3. Will have a look next week.
tgxworld
(Alan Tan)
July 25, 2016, 10:28am
11
Hmm I can’t find a <<~JS ` heredoc anywhere (including your plugins).
Have you resolved the issue?
Otherwise, can you run the following commands and provide the output here?
./launcher enter app
ruby -v
cat /VERSION
tgxworld
(Alan Tan)
July 25, 2016, 1:01pm
12
Ah I found it but the syntax we’re using is different and I’m not sure how to reproduce yet.
reloadable_patch { AnonymousAction.register(type, &block) }
# Applies to all sites in a multisite environment. Ignores plugin.enabled?
def add_report(name, &block)
reloadable_patch { |plugin| Report.add_report(name, &block) }
def replace_flags(settings: ::FlagSettings.new, score_type_names: [])
Discourse.deprecate(
"replace flags should not be used as flags were moved to the database. Instead, a flag record should be added to the database. Alternatively, soon, the admin will be able to do this in the admin panel.",
next_flag_id = ReviewableScore.types.values.max + 1
yield(settings, next_flag_id) if block_given?
reloadable_patch do |plugin|
cd/ var/discourse
git pull
Did the trick. Thanks
