Custom Topic Sort Order Button
Install this theme component
Hello :waving_hand:
This theme component adds a new button next to the Create Topic button, allowing you to change the topic list order. One of the main goals was to make topic ordering easily accessible on mobile devices as well and themes where the topic list header section is hidden.
Clicking on an item will show the sort order direction (ascending or descending) on the right side of the item.
Descending (icon) Ascending (icon)
Settings
This component contains several settings for customization.
Object setting
With the object setting you can change each item’s icon, label, action and order.
  • icon → icon name from the Discourse icon set
  • label → translation key (see /admin/customize/site_texts)
  • action → sorting action identifier
  • order → position of the item in the dropdown
Example for label:
likes-label
In this case the label field should be: js.likes
Great component! I thought about creating something similar.
I noticed you did not add a license to the GitHub repo.
Would you accept a pull request that adds more order options like op_likes?
this is a great component Don, nice work! thanks for creating this :star_struck:
Sure! PR welcome thanks @Moin :hugs:
One thing I noted is that I sort of expect the drop down to disappear after I’ve clicked one of the selections. I have to click outside it after the view changes to make it go away. But maybe that is by design - I’m not sure lol.
Yeah this is by design — if you click the same item again the sorting direction changes.
yea i was thinking that after playing with it more. i love this component - very useful for me on my own instance. thanks again :hugs:
I notice the sort by button appears on the categories page, but doesn’t do anything there. could probably hide it in that case.
Thanks Lilly :hugs: I’ve merged it: DEV: Remove sort button on categories page · VaperinaDEV/custom-topic-sort-order-button@1325272 · GitHub
It’s merged.
Icons and labels I chose for the additional order options
	"icon": "custom-heart-circle-one",
	"label": "js.category.sort_options.op_likes",
	"action": "op_likes"
	"icon": "user-group",
	"label": "js.posters",
	"action": "posters"
	"icon": "far-square",
	"label": "js.category.sort_options.category",
	"action": "category"
	"icon": "square-plus",
	"label": "js.topic_voting.vote_title_plural",
	"action": "votes"
I did not add these to the default configuration as I think these are less common. But when you add them, you can now also order by likes on the first post, number of posters, category ID, and by number of votes when the topic voting plugin is used.
I created an icon for likes on OP so you can distinguish between likes and likes on the first post even when labels are hidden on mobile.
at mobile when I choose a option this modal move to top until dom loaded
It’s a UI bug?
