Pulizia del database durante la scrittura di un nuovo script di importazione
Hello Friends,
I am trying to write an import script from OSQA to discourse. I have local Ubuntu installation of discourse. I wanted a way to know whether there is some cleanup script available which can delete all the data from all the tables of the discourse? Currently, when I run the script, the next time the entries already inserted are skipped.
If such a cleanup script was available, then I can experiment locally frequently, and it will help me essentially in writing such a script. If such a script is not available, then I guess my course is to just create stored function in PSQL.
Please guide me regarding this. I would be very thankful for this.
I’m executing the following commands whenever I want to rebuild my development instance.
cd ~/Repositories/discourse
rm -R public/upload/*
rm -R tmp/*
rm -R log/*
redis-cli flushall
bundle exec rake db:drop db:create db:migrate
Thanks a lot :slight_smile: It worked for me.
I always take a backup of an empty Discourse install with some tweaks made (admin user, allow_restore enabled, permalink settings, some adjusted limits to allow for a good import) and restore it when I want to start over again. Flushing redis is a good idea as well.
That’s what I usually do as well. :wink:
I have scripts for that too.
backup
#!/bin/bash
BACKUP_NAME=${1:-development}
mkdir -p /data/backups/discourse
pg_dump -d discourse_development -F c -b -v -f /data/backups/discourse/${BACKUP_NAME}.backup
restore
#!/bin/bash
cd /data/backups/discourse
rm -R public/backups/default/*
rm -R tmp/*
rm -R log/*
# close all connections because I usually forget to disconnect something...
psql -d postgres -c "SELECT pg_terminate_backend(pg_stat_activity.pid) FROM pg_stat_activity WHERE pg_stat_activity.datname = 'discourse_development' AND pid <> pg_backend_pid();"
redis-cli flushall
bundle install
pg_restore -d discourse_development -v /data/backups/discourse/${BACKUP_NAME}.backup
bundle exec rake db:migrate
thanks!
I got these error in docker:
root@infdis-app:/var/www/discourse# bundle exec rake db:drop db:create db:migrate DISABLE_DATABASE_ENVIRONMENT_CHECK=1
 DEPRECATION: The cocaine gem is deprecated. Please upgrade to terrapin. See https://github.com/thoughtbot/terrapin/ for further instructions.
PG::InsufficientPrivilege: ERROR:  must be owner of database discourse
: DROP DATABASE IF EXISTS "discourse"
Couldn't drop database 'discourse'
rake aborted!
but after I su - discourse, I got another error:
discourse@infdis-app:/var/www/discourse$ bundle exec rake db:drop db:create db:migrate DISABLE_DATABASE_ENVIRONMENT_CHECK=1
rake aborted!
Errno::EACCES: Permission denied @ rb_sysopen - /var/www/discourse/tmp/ember-rails/ember.js
You shouldn’t use my scripts from above inside a Docker container. They are meant for a Ubuntu development environment.
It’s a bit hard for me to build a development environment .
Is there any way I can go pass these error in docker?
Praveen were you able to create the migration script from osqa to discouse? If so would you share it with the wider community? Thanks
