Manually create and restore Discourse backups
As discussed below, a warning for newbies:
  1. this is an advanced method! there is an automated, web UI way to restore from backups at /admin/backups which is so much easier.
  2. with the method below, no automatic backup is kept of the /var/discourse/containers/app.yml file which contains essential SMTP credentials and SSL customizations. Keep a copy of this offsite whenever you change it.
  3. If you are using digital ocean, keep frequent snapshots of your droplets - preferably before each time you run ./launcher rebuild app or do any upgrades. Unfortunately in my case this takes an hour each time and it’s a manual process - but it’s totally worth it if you are not familiar with docker and want to avoid a headache later.
Continuing the discussion from Migrate db from old Discourse to new without updating:
Dropping and recreating the schema is required if the current database contains a table or view that the old one does not, because of referential integrity and pg_dump not adding CASCADE to its drop statements.
This could be easier if the extensions weren’t stored in the public schema.
Upgrading Discourse is not very hard, but there is always a risk involved. This is why creating a backup is always a strong recommendation before upgrades are installed – but what should you do when your current version is so old that it does not have the backup feature?
The safest way to do this is to not attempt any in-place upgrades on the existing, outdated Discourse instance. Instead, we will manually create a backup and import it into a blank but up-to-date Discourse instance.
Note regarding default path changes
The default path for the docker manager scripts has recently changed from /var/docker to /var/discourse. Since the main purpose of this howto is to help admins of older versions of Discourse to migrate to a new versions, I will use the old default path name throughout the howto.
If you have a newer version of Discourse and the docker manager, simply switch the path names mentioned above where appropriate.
Creating the backup
To create the backup, we need access to Discourse’s database and uploaded files. This depends a lot on your current setup. If you
  1. If your old Discourse…
  • lives in a Docker container, enter it:
    cd /var/docker
    git pull
    sudo ./launcher enter app
    su - discourse
  • does not live in a Docker container, you should at this point ensure that the user you’re logged in as can use pg_sql to connect to Discourse’s production database and has access to the uploaded files. You may also have to adjust the directory and file names below.
  1. Export the database and uploaded files:
    pg_dump -xOf /shared/discourse-backup.sql -d discourse -n public
    gzip -9 /shared/discourse-backup.sql
    tar -czf /shared/discourse-uploads.tar.gz -C /var/www/discourse/public uploads
  2. Almost done. Type exit twice to leave the container, then copy the files discourse-backup.sql.gz and discourse-uploads.tar.gz from the host’s shared folder, typicalls /var/docker/shared/standalone and store them somewhere safe. The SQL file contains password-equivalent material, so don’t put this file on a webserver and don’t send it unencrypted.
Restoring the backup
As above, this procedure depends on your particular setup, so this howto can only cover the case that you followed the supported setup instructions and have Discourse running in an up-to-date Docker container.
  1. Upload the backup files and copy them into /var/docker/shared/standalone, then run:
    gzip -d /var/docker/shared/standalone/discourse-backup.sql.gz
  2. As above, enter the container:
    cd /var/docker
  3. Flush your new Discourse’s database. This step is destructive; you must be absolutely certain that you are in the correct container, connecting to the correct database and that it contains no important data.
sudo -u postgres psql discourse <<END
DROP SCHEMA public CASCADE;
CREATE SCHEMA public;
ALTER SCHEMA public OWNER TO discourse;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS pg_trgm;
END
  1. Restore the backup data:
    su - discourse
    rm -rf /var/www/discourse/public/uploads
    tar -C /var/www/discourse/public -xzf /shared/discourse-uploads.tar.gz
    psql -d discourse -f /shared/discourse-backup.sql
  2. Bring the old database up-to-date by migrating it:
    cd /var/www/discourse
    RAILS_ENV=production bundle exec rake db:migrate
  3. Exit and restart the container:
    exit
    exit
    sudo ./launcher restart app
2개의 좋아요
Note if you’re migrating away from Heroku, you can’t use pg_dump on the server directly, so you’ll probably want to pg:pull your database to your local machine, and then follow the above directions from step 2.
You also will probably skip the commands related to uploaded files, since Heroku probably already forced you to use S3 for assets.
(Also, if for any reason you’re using pgbackup restore, be sure to pg:reset first or you might end up with a frankenschema like I did and your migrations won’t run.)
1개의 좋아요
(whoa, just found this old draft from months ago which apparently I never saved. Still relevant and hopefully useful to others who come after me)
I have some suggestions for improving this topic, having just wrangled (with success!) with restoring backups as a newbie.
  1. suggest adding text right at the top explaining that there is an automated, web UI way to restore from backups and link to a topic explaining backup and restore for beginners - I was not aware of this option until after attempting the manual process which is not for the faint of heart. I would even change the title of this howto to add “Advanced” or to specify that the topic is specifically for people with very old discourse sites.
  2. no automatic backup is kept of the /var/discourse/containers/app.yml file which contains essential SMTP credentials and SSL customizations. Keep a copy of this offsite whenever you change it.
If you are using digital ocean, keep frequent snapshots of your droplets - preferably before each time you run ./launcher rebuild app or do any upgrades. Unfortunately in my case this takes an hour each time and it’s a manual process - but it’s totally worth it if you are not familiar with docker and want to avoid a headache later. :slight_smile:
1개의 좋아요
It is wiki now, feel free to improve the howto.
1개의 좋아요
I am trying to restore from an earlier auto generated backup to S3.
The RAILS_ENV=production bundle exec rake db:migrate step seems to be overriding all the data even after I have restored the data with psql -d discourse -f /shared/discourse-backup.sql. I end up with a clean install in the end.
Probably of note: I have two containers, web and data.
What am I missing?
1개의 좋아요
Why aren’t you restoring the backup via the admin UI?
1개의 좋아요
Yep, @ernsheong restore through the admin UI then ./launcher restart both containers.
Wow, I love you guys! @riking @zogstrip :+1:
1개의 좋아요
permission denied (on the /shared folder).
1개의 좋아요
위키 게시물을 편집할 권한이 있는지 확실하지 않습니다. 제 실수일까요?
어쨌든, 명령어는 /shared/ 구조에 맞게 수정해야 합니다. 예를 들어:
다음과 같이 되어야 합니다:
tar -cvzf /shared/discourse-uploads.tar.gz -C /shared uploads
이 부분은 다소 중요하며, 현재 백업 명령어는 심볼릭 링크를 다른 마운트로 따르지 않기 때문에 빈 백업 파일 uploads.tar.gz을 조용히 생성합니다.
이 주제를 다시 올리는 것이 죄송합니다. :cry: 이 사용 가이드가 오래되었고 업데이트가 필요합니다.
제 인스턴스에 문제가 발생하여 더 이상 브라우저에서 액세스할 수 없습니다. 그래서 수동으로 사이트 백업을 가져오는 방법을 찾고 있었는데 이 주제를 발견했습니다.
도움을 주시면 감사하겠습니다!
아래 명령어를 시도해 보셨나요?
cd /var/discourse
인용하신 내용에서 오래되었다는 언급은 보이지 않습니다. 표준 설치인가요? /var/discourse/containers 디렉터리에서 무언가 확인되나요?
빠른 답변 감사합니다!
네, 여러 번 재빌드를 시도해 보았지만 계속 실패하네요… 그래서 새로운 드롭레트를 만들고 그 위에 새로운 Discourse 인스턴스를 성공적으로 설치했습니다. 그리고 한 달 전에 생성된 백업 파일을 복원했는데, 제가 하려는 것은 최근 며칠간의 데이터를 되찾는 것입니다.
네, app.yml 파일과 해당 백업 파일 하나 있습니다.
/var/docker 디렉터리는 존재하지 않아서 cd /var/discourse를 입력한 후 가이드를 따랐는데, pg_dump -xOf /shared/discourse-backup.sql -d discourse -n public 명령을 실행한 후 다음과 같은 프롬프트가 나타났습니다.
pg_dump: error: connection to database "discourse" failed: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: FATAL:  role "root" does not exist
저는 초보자인데, 만약 이 가이드가 실제로 오래된 것이 아니라면 불편을 끼쳐드려서 죄송합니다.
pg_dump를 시도하기 전에
  su - postgres
을 실행하셨나요?
그러나 데이터베이스 복원이 계속 불가능할 수 있는 문제가 있으므로, 재구축이 안 되는 이유를 파악하는 것이 더 좋을 수 있습니다.
2개의 좋아요
