خطأ في اتصال قاعدة البيانات عند إعداد بيئة تطوير Discourse باستخدام Linux Bash Shell على Windows 10
(error on this command)
bundle exec rake db:migrate db:test:prepare db:seed_fu
Based on the error message
PG::ConnectionBad: could not connect to server
I would double check that psql is installed and running
plsql is installed and database is created as well. I think the problem is on connecting with port 5432. The powershell is showing the port active. But, inactive in UBUNTU for windows terminal
Did you followed this guide? Where your Postgres is running. In “Windows” or “Ubuntu for Windows”?
I was able to figure out a solution to this issue.
When installing postgres, /etc/postgresql/10/main/postgresql.conf contained port=5433. Updating this to port=5432 fixed the issue for me. I ran into this when using Ubuntu on Windows.
Extra Credit:
Running sudo service postgresql status lets you know which port postgres is listening on.
